TR4/4A Steering Wheel Hub Issues
bammons
I just recently finished the restoration of my TR4A. I like the original wheel but I decided I need more leg room to get out of the car and not embarrass myself. So I bought a steering wheel and hub from Ebay. When I tried to fit it the horn comes on and stays on so I started checking and found that the three (I think) fold-over tabs that holds the "slip ring" in place are not there anymore. It worked with the original wheel (the upholstery shop put the steering wheel on which I had left loose so they could remove it easy). Being loose I think is allowing for unwanted contact and setting off the horn. So is there a way to replace/fix these foldover tabs? I have another issue which concerns the turn signal cancellation clip which fits over the steering shaft. I did not put it back on because I did not know to. I can see the dimples that it secures to but it seems that the light switch is too close and prevents it from slipping on. Also the shaft is not aligned properly so that clip is centered at the 9:00 position. Is the solution to pull out the splined porton where it goes into the first coupler in the engine compartment and turn the shaft? In searching I saw something about 3 screws holding something on the hub which I don't seem to have and I don't see in a parts diagram. Is this something I should have? Thanks for your answers in advance. Bruce
D Removing the steering wheel hub Spridgets 12
R TR2/3/3A Steering wheel hub removal Triumph 11
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
S Quick Release Steering wheel hub Triumph 1
H Midget steering wheel hub question Spridgets 1
H Midget steering wheel hub question Other Cars 0
B Nardi steering wheel hub MG 1
ModifiedBJ7 Steering Wheel Hub Removal Austin Healey 5
jjbunn Steering Wheel and Hub Removal MG 43
G Steering wheel hub adapters. Spridgets 9
toysrrus Looking for a Series I Steering Wheel Hub Jaguar 8
George Zeck Steering Wheel Hub ? Spridgets 6
R Nardi steering wheel hub Triumph 0
T TR6 Steering Wheel Lock Triumph 2
K 1968 Midget Steering wheel Spridgets 1
Editor_Reid Wrapped Steering Wheel Austin Healey 9
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ā€˜74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
kodpkd Leather Steering Wheel Cover Austin Healey 3
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
LAW75 Derrington Steering Wheel Austin Healey 19
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
A Austin A40 trafficator steering wheel Other British Cars 5
T Steering Wheel Adjustment Range Austin Healey 0
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
D Steering Wheel Repair Austin Healey 2
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
