Steering Wheel Hub ?
George Zeck
Hi all --
The last post about selecting a stering wheel got me thinking a bit. I would like to upgrade to a wood stering wheel on my '64.
I've never removed a wheel before and am only talking "conceptually" - which usually gets me into trouble. After searcing Moss / VB & Summitt. Nothing specific to my year of car.
Has anyone ever modified this to work? Can it be weleded or bolted to operate? Again, never doing this before is a problem - but it would be such a nice touch.
Also - planing to remove dash and replace with a nit piece of walnut or oak overlay (stained to match the wheel). I took a quick look at this and seems quite doable. The two together would be stunning !
Any thoughts onthis would be welcome.
Tx-
Geo
drooartz
Moss has wheels and adaptors that should work for your car. Moto-Lita style wheels will work; they make an adaptor for all years of Sprites, I believe.
Moss carries Moto-Lita and Tourist Trophy (similar to Moto-Lita, but about $100 cheaper), which should both work for your car. Nice looking wheels.
Your MK2 should be the same spline type as a Bugeye, I think. You can also go to Mike Lempert for a custom wheel. He makes the hubs as well, and I think they would work on your car.
Wood dash shouldn't be too hard to do. Some forum members have done this, and I'm considering it if I ever do the RHD conversion I've thought about. Your MK2 has the flat dash, right? That should be a piece of cake.
bugimike
I have re-done my BE dash with wood veneer. You do not have to remove the dash. You do have to remove all switches and instruments, first to trace a pattern, and then to apply it. I used a nice teak marine-grade veneer about 1/16th" thick. Only a few strategic dabs of contact cement were used, as once the switches and instruments are replaced, they hold the wood in place! The thinness of the veneer allows cutting out all the holes after the panel is installed with an X-Acto knife, taking the guesswork out of lining up holes! Walnut veneer in the right thickness should be available too! A nice finish coat and it will look like a Rolls dash!
If you buy a Motolita hub, then you can also use many Lecarra steering wheels sold by places like summit racing.
tony barnhill
Great Pumpkin - R.I.P
I have Moto-Lita on my V8 car, a Nardi on my '67 GT & '63 Midhet & was in love with them until I bought my first Tourist Trophy - now I have a TT for all my other cars!!
The TT look nice, but I avoided them because I was not certain where they were made. The TT is a Moss branded item and they are built by whoever gets the bid. (They may be made by LeCarra, but they may also be made in China.) I generally try to buy from sources where I know the labor source.
Again, I'm not knocking the quality, I'm just making a statement of personal preference.
BTW, LeCarra wheels are made in TN and if you want a leather wrapped wheel to match your interior, then you can supply them with the leather.
Whitephrog
I used a Moto-Lita hub with a Lecarra wheel on my Bugeye. Worked perfectly. Lecarra wheels are now made in East Tennessee about 30 miles away. They have a nice hub that works with later Sprites and Midgets but not Bugeyes.
D Removing the steering wheel hub Spridgets 12
B TR4/4A Steering Wheel Hub Issues Triumph 0
R TR2/3/3A Steering wheel hub removal Triumph 11
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
pkmh Removing BJ8 'Adjustable' Steering Wheel Hub Austin Healey 18
S Quick Release Steering wheel hub Triumph 1
H Midget steering wheel hub question Spridgets 1
H Midget steering wheel hub question Other Cars 0
B Nardi steering wheel hub MG 1
ModifiedBJ7 Steering Wheel Hub Removal Austin Healey 5
jjbunn Steering Wheel and Hub Removal MG 43
G Steering wheel hub adapters. Spridgets 9
toysrrus Looking for a Series I Steering Wheel Hub Jaguar 8
R Nardi steering wheel hub Triumph 0
T TR6 Steering Wheel Lock Triumph 2
K 1968 Midget Steering wheel Spridgets 1
Editor_Reid Wrapped Steering Wheel Austin Healey 9
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
kodpkd Leather Steering Wheel Cover Austin Healey 3
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
LAW75 Derrington Steering Wheel Austin Healey 19
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
A Austin A40 trafficator steering wheel Other British Cars 5
T Steering Wheel Adjustment Range Austin Healey 0
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
D Steering Wheel Repair Austin Healey 2
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
