Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2]
Martinld123
Martinld123
Bronze
Hello, while replacing oil seal on my 1956 Healey BN2 steering box it looks like the steering wheel might have inadvertently been turned. So is there a way to recenter the steering box? I guess if off center the turning radius would be less one way and more the other? Thanks Marty
kodpkd
Did you pull out the main steering rod from the box? You could remove the rod and make it correct,, remove the steering wheel, or install adjustable tie rods.
mezy
turn steering fully one way, measure to a fixed point,
turn steering fully the other way and measure to the same fixed point
deduct one measurement from the other devide by two, then add that to the first measurement.
that will give you centre position from the fixed point, then remove and refit steering wheel
Martinld123
Martinld123
Bronze
No, I did not remove steering rod from the box. When I pulled the the arm off of the steering box it looks like the Steering wheel might have been turned so I thought it would be good idea to check centering. Thanks
Martinld123
Martinld123
Bronze
I did not remove steering wheel just pulled steering arm off of steering box so I could add new seal on top of existing seal that leaked. The leak has stopped so I want to reassemble now but first check box centering. Thanks
Martinld123
Martinld123
Bronze
Doesn’t the arm only fit back on one way?
Thanks, I wish that were the case but as you can see from photo there are no arm set locations with equal spaced splines all around. So I did mark the arm location on case and arm but I want to check steering wheel center before I it back together. Any ideas? Thanks
red57
Martinld123, Here are pictures of the splines on the shaft and arm.
First is a pitman shaft (twisted in an accident so not useable) that clearly shows one of the 4 double splines.
Second is the pitman arm that shows the 4 double spline locations that only allow it to go on in 4 different locations. So you are either correct or off 90* or 180*
Martinld123
Martinld123
Bronze
Second is the pitman arm that shows the 4 double spline locations that only allow it to go on in 4 different locations. So you are either correct or off 90* or 180*View attachment 85110
Thanks for photos but after cleaning and inspection I found all splines are all equal. My car is a BN 2 but steering box could be a BN1. Fortunately I had both parts case and arm marked but steering wheel location is what I was not sure of. Looks good so far but my fuel pump just went out so cannot test. Will Post fuel pump question tonight to decide where to buy. It is electronic. Thanks
L Alignment and steering wheel position Austin Healey 4
GBRandy Wedge TR8 Steering Wheel Alignment Triumph 6
I Steering wheel alignment Austin Healey 8
jhorton3 Steering Wheel and Alignment Spridgets 6
zimmy steering wheel alignment Spridgets 4
B Steering Wheel Alignment MG 8
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
K 1968 Midget Steering wheel Spridgets 1
Editor_Reid Wrapped Steering Wheel Austin Healey 9
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
kodpkd Leather Steering Wheel Cover Austin Healey 3
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
LAW75 Derrington Steering Wheel Austin Healey 19
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
A Austin A40 trafficator steering wheel Other British Cars 5
T Steering Wheel Adjustment Range Austin Healey 0
R TR2/3/3A Steering wheel hub removal Triumph 11
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
D Steering Wheel Repair Austin Healey 2
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
S Wedge tr7/8 quick release steering wheel Triumph 0
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
