    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
TR2/3/3A Making your own steering wheel stator tube?
TomMull
Certainly can't add much to that except that my increasingly unsteady hands would make cutting the slot free hand difficult so I used an end mill in my drill press with a slinging vise. If you have an adjustable wheel, the slot is a lot longer.
Also recall that Macy's had some plastic bearings to replace the metal "lanterns" in case you can't use yours.
Tom
sp53
I purchased the material for making one at a large commercial truck parts store were they make hydraulic lines. I forgot what they use the line for, but they had it in stainless. It was rumored that Moss sells one for the Austin Healy that will fit a tr3
TomMull
Dave, That link says 5/16 OD. I'm pretty sure it should be 3/8. Pretty easy to come by. I got mine at Grainger. It shipped to store free, pricey if otherwise. Tom
DavidApp
Hello Tom
It is 3/8" OD
When I look at my book mark for the tube it says 3/8" and I must admit I did not check the Amazon site for the specs.
David
TomMull
Yup, my loft if full of similar mistakes made over the past 50+ years.
Tom
sp53
Are you asking about the timing photo and whether the apex of the pointer at the hole is TDC or the start of the pointer angle being TDC? The apex is TDC
K
karls59tr
Bronze
No. I was not talking about the photo Randall sent. I'm referring to a photo of the timing mark I saw in the collection of photos that CJD was kind enough to send when I was making stator tube inquiries.
CJD
Found it down in post #43. That photo shows about 3-4 degree before. If you look at the fan to determine the direction the crank rotates, it makes it easier. In that picture the crank has not quite reached the marker, so it is BTDC. The way I set the initial timing is I pulled the number one plug and left the ignition on as I slowly turned the crank. When the spark flashed I stopped turning and noted the position of the marker. I then adjusted the dizzy until I got the mark where you see it when the spark flashed. That is good for initial starting, but after running I have since advanced it several degrees after drive testing.
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
Got_All_4 TR2/3/3A I'm making my own door panels and .... Triumph 11
A Why is my car making this noise? Other Cars 5
mctriumph 61 Morgan making progress Other British Cars 3
KVH General Tech Making the Triumph Engine Dolly Triumph 4
A Making an A-series engine stand adaptor fitting Spridgets 2
H Making a '73 Midget into a '63 Midget Spridgets 2
matmire gonna try making some wind wings. Spridgets 13
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
D 69 E-Type sputters when making left hand turn Jaguar 6
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
tomshobby General TR making it easy to lube door hinges Triumph 0
drooartz Making [tiny] progress Spridgets 14
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
7 Post-War Other Back to making progress Triumph 5
glemon Restoration Vs. Making it Go Restoration & Tools 14
drooartz MGB Making some progress with the doors MG 5
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
G How do I know I am making the right decision? Jaguar 7
AN5Sprite Making room Spridgets 0
J Making Room Triumph 2
RickB Who can guess what I'm making? Spridgets 37
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
Darrell_Walker Making a wire wheel tubeless? Triumph 45
Aggudabbu Making some progress Spridgets 5
glemon Making Strombergs Richer Triumph 22
F Are the russians making a hybryde .... Other Cars 0
hondo402000 Making your Avatar Pic Triumph 14
Sarastro Tool for making bubble flares on brake lines Restoration & Tools 14
M_Pied_Lourd Making Progress Triumph 314
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
G Making a faux roll bar into a real roll bar Triumph 2
RickB OT: talk about making a Spridget Hybrid? Spridgets 0
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
drooartz Making more calls today Spridgets 6
T Making a steering wheel Austin Healey 41
DNK My 6 is Making Me Frustrated Triumph 10
Stewart Making progress finaly MG 7
T Making straight cuts & smooth edges for patches Triumph 5
George Zeck Making good progress ..... Spridgets 11
7 Making progress finally Triumph 1
G Still making the covers after 30+ years Triumph 0
healeyboz Making the switch to Spridgets 19
drooartz Making a dashboard Spridgets 28
S I'm making it WORSE! HELP! Triumph 15
G Making my winter maintenance checklist Triumph 11
KLUTZ MGB-GT Making progress on the GT MG 14
