General Tech Making the Triumph Engine Dolly
KVH
I'm now making a dolly to "hold" my engine until I'm ready to mate the transmission. I'm using a furniture dolly as a base, just like others have done. I'm following the threads and posts from Mike as well as others here, but I can see I need more advice. The engine block length, oil pan flange to flange, is right about 19 3/16". My main question now is whether the depth of the dolly should be an extra few inches, like 22 inches, just for comfort, with the idea that I'd just slide the engine forward a bit when I'm ready to mate the transmission, or whether I just ought to make the depth match the block length, right at 19 3/16 plus or minus. It doesn't make much difference to me, but I wanted to toss out the issue in case any of you has an idea or experience relevant to the final dimensions, problems with dimensions, etc. Thanks
charlie74
When I did mine (for my TR 6) it looked like this. The 3 sides were standard dimensional 6”. The manifold side was a 2x6, and the other two were 1X6. The open end (to accommodate the rear engine plate) is just a bit of strapping that i had lying around. My bottom board should maybe have been wider to spread the load on the dolly so it was supported more directly on top of the casters, but I just slipped a couple of thin planks under the cradle to help spread out the load.
You can see the sump bolt head locations are evident in the wood so the engine is quite well supported.
If your anywhere near Ann Arbor, MI you can have mine.
edit: Having said all this though, my transmission remained in the car. My guess is that that shouldn’t matter though as long as the rear engine plate is unobstructed so you can mate up the gearbox…
KVH
KVH
Thanks. That is very helpful. One thing that’s not clear to me, though, is that a little strip where the rear of the engine would sit. Why do you have a strip of wood there? Shouldn’t that just be left open?
KVH
KVH
Oh I see. I’ve got it. You’re high enough on the sides to clear the front support piece.
Popeye
Bronze
I would not add extra length, if only because moving the engine is difficult. Also when the flange opposite the transmission is not on the dolly (engine shifted towards transmission), you lose the “left-right”stabilizing effect it has.
Maybe more importantly, how long will the engine be on the dolly, and will it be in a place where you can easily knock it? I found my engine on the dolly to be reasonably stable. I would not roll it down the street, but carefully on the garage floor was not an issue.
A Why is my car making this noise? Other Cars 5
mctriumph 61 Morgan making progress Other British Cars 3
A Making an A-series engine stand adaptor fitting Spridgets 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
H Making a '73 Midget into a '63 Midget Spridgets 2
matmire gonna try making some wind wings. Spridgets 13
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
D 69 E-Type sputters when making left hand turn Jaguar 6
Got_All_4 TR2/3/3A I'm making my own door panels and .... Triumph 11
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
tomshobby General TR making it easy to lube door hinges Triumph 0
drooartz Making [tiny] progress Spridgets 14
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
7 Post-War Other Back to making progress Triumph 5
glemon Restoration Vs. Making it Go Restoration & Tools 14
drooartz MGB Making some progress with the doors MG 5
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
G How do I know I am making the right decision? Jaguar 7
AN5Sprite Making room Spridgets 0
J Making Room Triumph 2
RickB Who can guess what I'm making? Spridgets 37
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
Darrell_Walker Making a wire wheel tubeless? Triumph 45
Aggudabbu Making some progress Spridgets 5
glemon Making Strombergs Richer Triumph 22
F Are the russians making a hybryde .... Other Cars 0
hondo402000 Making your Avatar Pic Triumph 14
Sarastro Tool for making bubble flares on brake lines Restoration & Tools 14
M_Pied_Lourd Making Progress Triumph 314
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
G Making a faux roll bar into a real roll bar Triumph 2
RickB OT: talk about making a Spridget Hybrid? Spridgets 0
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
drooartz Making more calls today Spridgets 6
T Making a steering wheel Austin Healey 41
DNK My 6 is Making Me Frustrated Triumph 10
Stewart Making progress finaly MG 7
T Making straight cuts & smooth edges for patches Triumph 5
George Zeck Making good progress ..... Spridgets 11
7 Making progress finally Triumph 1
G Still making the covers after 30+ years Triumph 0
healeyboz Making the switch to Spridgets 19
drooartz Making a dashboard Spridgets 28
S I'm making it WORSE! HELP! Triumph 15
G Making my winter maintenance checklist Triumph 11
KLUTZ MGB-GT Making progress on the GT MG 14
