TR2/3/3A TR3A electrical issues
Dave L
To All,
I have two electrical issues I can't figure out:
1st issue: Horns
I wired up my horns yesterday and am still having issues, I had an issue with the contact on the horn button falling off and grounding out. I removed the horn button and fixed it and think I have them wired correctly.
D side​
NG wire to horn from harness​
NB to horn from 4 way connector.​
NB from steering column to 4 way connector.​
NB wire from main harness to 4 way connector.​
P side​
NG wire from harness to horn.​
NB wire form harness to horn.​
When I turned on the power to the car, the horns started blowing. I turned the power off and messed with the NB wires in the 4 way harness, turned power back on, now nothing?​
2nd issue: Headlights
Connected both blue/red and blue/white to harness.​
Turned on power and have 12v to blue/red circuit nothing to blue/white.​
I had a relay kit from Moss installed.​
I checked the voltage working back from the headlight buckets, no power to them, no power to them at the high beam switch, no power to them at the relay.​
I removed the relay and bench tested it, it tested ok.​
I replaced it with a new one and I still get no power to the wires?​
The car sounds like it needs a bearing in the water pump or alternator ,and the amp gauge pegs to the right when I pull the switch for the lights. when I shut them off, the gauge goes back to normal and the grinding noise under the hood goes away?​
I am at a loss as to what to do next.​
Any help would be greatly appreciated​
Thanks,​
Dave​
CJD
If it involves both horns, that narrows the problem to the wiring from the horn button to the driver's 4-way connector. So, the NB at the 4 way from the steering column should normally read battery voltage. Press the horn button to see if it goes to 0v. If not...then you have a button or steering harness problem. If it does, then the 4-way connector is at fault.
I am not familiar with the relay mod...but no power anywhere sounds like the power feed to the relay.
Dave L
Thanks,
does it matter which way I plug in the NB wires in the 4 way connector?
Dave
R TR2/3/3A Intermitant electrical issues TR3A Triumph 3
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
Gordon_Dedrick TR2/3/3A 59 TR3A Intermittant electrical issue, Triumph 5
PatGalvin TR2/3/3A TR3A Electrical Questions Triumph 7
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
S TR2/3/3A TR3A Electrical Triumph 9
angelfj1 TR2/3/3A TR3A - Wiper Motor Electrical Connections Triumph 5
Got_All_4 TR2/3/3A TR3A Electrical and Missing Problem Triumph 8
J TR2/3/3A tr3a electrical troubles Triumph 35
mrv8q TR2/3/3A TR3A Electrical dilemma Triumph 5
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
