TR2/3/3A TR3A Disk Brake Question
T
TR3-Stu
I fired up the TR and took it for it's first short test hop down the street (slightly illegal) . Had a good firm petal before I started off and the handbrake worked perfectly. After the first application of brakes, the front disks are firmly still on. The car will move, but will not coast at all. The calipers are brand new Moss units as are the pads; I drilled out the restrictor valve after I had trouble bleeding the brakes and finding an earlier post about problems with that valve; - why would the pressure at the disks remain high after I'm off the brake petal? Help
Stu
bobhustead
Freeplay in the master cyl push rod could be a problem. Also, new pads are often too thick. With wheels off, can you pry the pads back to where the rotors spin freely?
Bob
CJD
If you are sure the restrictor is disabled, then my thought is along with Bob...check that the master cylinder piston is returning fully to the stop. It could either be the rod is adjusted too long, or the new MC piston is "sticky". You will have to remove the rubber boot to make sure. The rod could be loose, but the piston still short of retracting. It must fully retract to vent the brake lines.
bobhustead
Two more thoughts. A mechanical bind keeping pedal or push rod from returning to original position. Or, the clevis pin somehow mispositioned (this latter seems unlikely, but possible).
Bob
bobhustead
I just went out and looked at my car. It looks like it could be possible for the pedal end of the pushrod to foul the right front bolt (or something trapped against it) that holds the pedal box to the firewall.
Bob
T
TR3-Stu
John, Bob, Geo, and team Hamish
Thank you for all the useful suggestions and hints. I wasn't clear on my 'drilling out' the restrictor valve - as Geo said, I just removed the springy thing. As to the new pads, when I installed them they went in easily and each wheel rotated smoothly, so it seems to be pointed at the MC. I will be out there today checking the MC closely as it sounds like that is my problem. Thanks again for the quick responses - this forum and it's members are so valuable.
Stu
T
TR3-Stu
Brake MC update - thanks to all of your valuable advice, I checked the MC play/throw and, as several members suggested, my adjustment was not allowing the MC piston to fully retract. Simple fix with immediate good results.
Lesson learned - there's always more to learn. I started working on British cars when I was 16 (1st car was a '55 small-mouth TR, 2nd, a '56 MGA), then got away from British vehicles for quite a while, but still considered myself a decent mechanic. I'm always humbled by what I don't know, or have forgotten.
Thanks again for all the help.
Stu
rlandrum TR2/3/3A TR3A Disk Brake Rebuilding Triumph 9
rlandrum TR2/3/3A TR3A Disk Brakes Triumph 4
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Hamish Racing TR2/3/3A TR3a video Triumph 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
angelfj1 TR2/3/3A TR3A Stone Guards Triumph 3
