Wanted TR3A rear seat peg and clip
Frank Canale
I am looking for the peg and clip that holds the rear seat in place. I need 2 of each. I thought I could order these from Revington TR in the UK but they are no longer available. Does anyone have a set they would like to sell? Frank
TR4nut
View attachment 78574View attachment 78576I am looking for the peg and clip that holds the rear seat in place. I need 2 of each. I thought I could order these from Revington TR in the UK but they are no longer available. Does anyone have a set they would like to sell? Frank
Frank -
if you are still looking, Bresco in the UK had them the last time I looked.
Randy
F
Frank Canale
Thank you, Randy. Once again the forum comes thru for me. That is an amazing catalogue, I will be in touch to see if they have the peg and clip in stock. Frank
Got_All_4 TR2/3/3A Triumph tr3a occasional rear seat Triumph 14
ekamm TR2/3/3A Rear seat tr3a Triumph 4
CraigLandrum TR2/3/3A TR3A Rear Seat Questions Triumph 13
J TR2/3/3A TR3A Girling 9" Rear Brake Initial Adjustment Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
D TR2/3/3A assembly, TR3A rear fender and radiator stays Triumph 22
JFS TR2/3/3A TR2 Rear Plate Lite on TR3A Triumph 10
JohnnyMead TR2/3/3A TR3A Rear Wheel Cyl Assembly Question Triumph 5
luke44 TR2/3/3A TR3A Rear Trim Panel Triumph 7
M_Pied_Lourd TR2/3/3A TR3A Rear Bumper Distance Tubes Triumph 11
tinman58 TR2/3/3A TR3a rear Diff seal Triumph 8
TR3Dad TR2/3/3A TR3A Loud Buzz & Rear Axel Triumph 3
T TR2/3/3A TR3A rear valance lower seam Triumph 2
M_Pied_Lourd TR2/3/3A TR3A Rear Close Out Panel Triumph 5
J TR2/3/3A TR3A rear view mirror placement Triumph 13
K TR2/3/3A Needs Picture of Rear TR3A Brake Assembly Drum Off Triumph 6
M_Pied_Lourd TR2/3/3A TR3A Rear Valence Triumph 12
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
Tinkerman TR2/3/3A Rear Valance TR3A post 60000 Triumph 6
G TR4/4A tr4 rear end in a tr3a Triumph 10
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
M_Pied_Lourd TR2/3/3A TR3A Rear Brakes Triumph 5
MGTF1250Dave TR2/3/3A TR3A Rear Axle Pinion Oil Seal Replacement Triumph 8
M_Pied_Lourd TR2/3/3A TR3A Rear Axle Help Triumph 25
H TR2/3/3A TR3A Rear Bumper Triumph 5
H TR2/3/3A TR3A Rear Bulkhead Triumph 9
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
K TR2/3/3A TR3A: Refilling rear shocks? Triumph 4
Tinkerman TR2/3/3A TR3A Rear Wing Clamp Installation Triumph 14
Tinkerman TR2/3/3A TR3A Rear Fender Stone Guards Triumph 4
M_Pied_Lourd TR2/3/3A TR3A Rear Brake Opinions Triumph 12
Got_All_4 TR2/3/3A Needed TR3A front and rear fenders Triumph 4
mcguijo TR2/3/3A Clamp plate on Rear Fender TR3A Triumph 16
rlandrum TR2/3/3A TR3A Rear Axle Picture Triumph 29
J TR2/3/3A TR3A Rear Brake Cylinders Triumph 1
T TR2/3/3A TR3A rear end ratio Triumph 1
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
P TR2/3/3A TR3A Rear Crankshaft Seal Triumph 2
Don Elliott TR2/3/3A Late TR3A Rear Interior Support Triumph 11
G TR2/3/3A TR3A rear fender captive bolts Triumph 7
C TR2/3/3A TR3A 10 inch rear brakes Triumph 7
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
