TR2/3/3A Needed TR3A front and rear fenders
Got_All_4
Hi everyone. I have a customer that is looking for a set of front and rear fenders for a 1961 TRA. He is stripping his customers car and ran into some major horrible patch work that had tons of bondo work over top. It's a shame because the rest of the car is extremely sold. He is a collision shop that does a few restorations to keep the guys working during slow times so he does not good sources. He exhausted the ones I gave him. The current fenders would take about 40 hours of work to straighten and would rater put the $ some ware else into the project.
The other shame is this is the 2nd time the car has been done in 3 years. The previous work was done by a body technician in his home shop and there was a lot of dirt in the paint and filler cracking all over the place. Not a lot of interest in northeastern Ohio for these cars and most shops don't want to work on them and when they do the craftsmanship is less the desirable. Thanks Larry
Brosky
Will he consider fiberglass fenders? I know a guy in CT who has some for sale if he is interested. I have no financial interest, I just know that he is selling off all of the parts that he accumulated for a TR3 restoration, then sold the car and bought a BMW Z-4 to keep his wife happy.
Got_All_4
Got_All_4
I think it might be his last resort. I heard that the fiberglass fenders were a horrible fit. Might have the same results in fitting time and I would think he'd rather have the metal fenders. I will ask. Thanks.
AweMan
I too would dearly love to find some reasonable used steel front fenders for my 56 Tr-3 I do however have one extra rear {Drivers side fender} no RUST but looks like a sack of potatoes. {would need some TLC with body hammers and dollys} I`m sure it can be salvaged. {NO dents in the curved areas} All of the lumps are on the flat surfaces. It does have two minor cracks, one on the wheel well flange and one in the middle of the flat surface and has been {attempted} welded. {No burn through but would need attention}. IF interested contact me via email {Available in my profile.
P.S. If I have my friend Tin Beater straighten it out it will go for a lot more than I am willing to part with it as is!
Tinkerman TR2/3/3A Front windscreen help needed. TR3A 1960 Triumph 9
B TR2/3/3A 1958 TR3A front body attachment help needed Triumph 7
2 Wanted SU-h6 Carb. BODY ONLY needed, badly worn. for TR3A Triumph Classifieds 5
P TR2/3/3A Help needed. TR3A transmission popping out of 1st gear Triumph 13
T TR2/3/3A TR3A Sheet Metal Piece Needed Triumph 2
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
Tinkerman TR2/3/3A TR3A Vacuum Advance Suction Tube Tool Needed Triumph 8
Tinkerman TR2/3/3A TR3A Part Needed Triumph 4
A TR2/3/3A TR3A apron picture needed please Triumph 4
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
T TR2/3/3A TR3A braking part needed Triumph 11
Tinkerman TR2/3/3A TR3A Part Needed Triumph 3
T TR2/3/3A Opinions needed on possible sale of my 60 TR3A Triumph 13
MGTF1250Dave TR2/3/3A TR3A Door Handle Latch Part Needed Triumph 9
Tinkerman TR2/3/3A TR3A Handbrake Help Needed Triumph 9
CraigLandrum TR2/3/3A TR3A Windshield washer info needed Triumph 9
T TR2/3/3A Multiple parts needed for a TR3A. Triumph 18
T TR2/3/3A TR3A overdrive conversion - whats needed Triumph 6
T TR2/3/3A Tr3A rear main seal conversion - adviced needed Triumph 11
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
H TR2/3/3A Rock guard needed Triumph 2
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
P MGB Zenith water choke gasket needed MG 4
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
T Wanted BJ7 parts needed Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
E GT6 Help electrical guru needed Triumph 4
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
tr6web TR6 More leg room needed Triumph 5
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
R Rust in Block? Help needed! Austin Healey 6
steveg TR6 Hood release pictures needed Triumph 22
steveg Picture needed - front turn light Austin Healey 4
steveg TR6 Spec needed for correct ride height Triumph 28
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Mickey Richaud TR4/4A TR4 Head Needed Triumph 4
D New Battery Needed for BJ8 Austin Healey 9
Michael Oritt Tenax fastener source needed Austin Healey 6
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
N Electrical Troubleshooting Advice Needed Spridgets 6
