TR2/3/3A TR3A overdrive conversion - whats needed
TFR
Looking to install an A type overdrive in my non-overdive car. What would I need in parts to make it work?
Thanks for your help.
An overdrive to start. The proper dash switch, which for your car should be the big monstrosity toggle unit that fits to the left of the steering wheel near the heater switch.
Wiring harnesses, upper and lower; relay; and solenoid. I can't remember if you need different mounts.
If you are mounting an overdrive to your existing transmission, you will need a new main shaft.
you do not need different mounts.
You'll also need the adapter plate that goes between the OD and the gearbox; plus the isolator switches for the top of the shift cover. If your shift cover is not drilled and tapped for the switches, you'll need to do that too. (Takes an unusual metric tap, 16x2.0 as I recall.)
But the wiring is trivial to fabricate on your own, and almost any switch will work. The original 'teardrop' is nice because it puts the toggle where you can hit it without taking your hand off the steering wheel.
Mounts are the same (if you get a proper TR A-type OD), driveshaft is the same; but you'll need a different, longer speedo cable. Speedo itself does not change.
Note that installing the OD requires partial disassembly of the gearbox; might as well replace the seals, 2nd gear synchro and countershaft/bearings while you're in there.
I would suggest a few modifications (unless you're a purist)
1) Add a diode across the relay contacts to absorb the kickback from the solenoid. If you do this, you can use an ordinary 12v automotive relay.
2) Add a fuse in the power to the relay and solenoid. In addition to reducing the chances of fire if you have a short, it will protect the pull-in coil inside the solenoid, if for some reason the plunger hangs up.
3) Although the factory powered the OD solenoid from the battery side of the ammeter, I moved mine to the load side. That way, the ammeter tells me a bit about what's going on if the OD doesn't work the way I expect. I can see the needle kick for the pull-in solenoid, and just barely twitch for the holding coil.
4) If you are going to have the shift cover apart, add "backing washers" to the (new) shifter shaft seals. Eg MMC P/N 9560K53. I don't know if the original seals actually fit or not, but the seals sold today (which are just O-rings) don't fit right and leak.
I actually bought "double seal" O-rings to go on top of the washers, which seem to work very well. If they hold up on the car, I may offer kits of 3 O-rings & 3 washers (since I bought 100 of them).
Thanks guys... man some good stuff here.
I am on track for buying a nice A type. After that I'll need to locate the above listed stuff.
deadair TR2/3/3A TR3A Overdrive Conversion Triumph 7
RichB4493 Wanted TR3a overdrive dashboard switch Triumph Classifieds 0
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
D TR2/3/3A TR3A overdrive question Triumph 6
T TR2/3/3A Overdrive emblem on TR3A? Triumph 25
6TTR3A TR2/3/3A TR3A overdrive relay question Triumph 3
Tinkerman TR2/3/3A TR3A Overdrive Relay Triumph 12
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Q TR2/3/3A TR3A Overdrive Adaptor Plate!! Triumph 1
luke44 TR2/3/3A Early TR3A Overdrive relay location Triumph 5
T TR2/3/3A tr3a overdrive vendor questions Triumph 19
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
T TR2/3/3A Stebro Exhaust on TR3A w/ Overdrive? Triumph 10
B TR6 TR6 "A" Overdrive fitted to a TR3A? Triumph 12
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 23
C TR2/3/3A TR3A Electrical problem Triumph 20
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
