TR2/3/3A TR3A Boot Millboard Install
angelfj1
Hello friends. I recently purchased a replacement millboard for my 59 TR3A. The old millboard was more like heavy cardboard and has several scuffs and tears in the surface. The new one, from TRF, looks like "Masonite" with a covering of very thin black vinyl material. The millboard is secured in place with 10 chrome plated trim screws and cup washers. The replacement millboard came from TRF without any holes for the mounting screws. I tried using the old millboard as a template for drilling the new one. However, the shape of the new millboard was somewhat different. So, I was off enough to make it impossible to fit. I hesitate to drill new holes in the top and bottom sheet metal "flanges". Has anyone replaced one of these millboards and/or do you have any tricks or suggestions on how to accurately line up and drill the mounting holes?
Many thanks, Frank
Hamish Racing
I recently took mine out of my 3a to dry out the boot (trunk) after a racing in heavy rain.
the PO did a great job of making the new board out of thin plywood with thin carpet glued on. Top goes in first up against the central metal “flanges” with the outer “ears” above the wheel arch then push the bottom in on top of the boot carpet. It’s a tight push fit without any screws needed.
CJD
There are several ways to transfer the hole locations to your new board. The first that comes to my mind is to thread sheet metal screws into the tabs...backwards. You can then press the board up to the screw and push hard enough to leave a mark. Then drill a hole at each mark.
mctriumph
Use the old plate to re-shape the new one to fit. then drill holes where they go I use a little 80 grit
on a grinder. to whittle it down EZ PZ.
Mad dog
TRopic6
Many thanks, Frank
Hi Frank, Like Mad dog, I had to do goodly sanding to get the replacement boot board to fit, especially around the wheelwells. Final fit was nice and did like John to get the holes in the board to line up with the body flange holes.
Jeff
mctriumph
If you use the boot at all , I suggest covering the finished board with black vinyl. Myself, I just start with millboard
from the lumberyard, and cut it with a jigsaw to shape. Sand it to size and cover it. Reminds me to buy some vinyl
today and finish my 59's boot......
Mad dog
jfarris
Mine, with a medium thickness carpet on it, is like what Hamish has. Fit at top, push in at the bottom, no screws.
mctriumph
jfarris has the ticket, pressed mine into place after the covering was on it. Nice and tight ,no screws needed.
Going to make up some trims for the side panels with the millboard scraps since the vinyl on the wheel tubs
looks so sweet. It will look nicer than new.
Mad dog
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
S TR2/3/3A Triumph TR3A Boot Floor Replacement - Looking for help Triumph 13
T TR2/3/3A Kuhmo 165/80-15 tires will NOT fit in spare boot for post TS60000 TR3A. Triumph 23
PatGalvin TR2/3/3A Boot Lid Reinforcing Supports Question, TR3A Triumph 8
angelfj1 TR2/3/3A TR3A - Boot Lid Handle Triumph 6
Tinkerman TR2/3/3A Boot Lid Seal TR3A Triumph 7
Tinkerman TR2/3/3A TR3A Boot trim out.question. Triumph 17
ekamm TR2/3/3A Boot closeout for fuel tank tr3a Triumph 13
angelfj1 TR2/3/3A TR3A - Fuel Tank/Boot Fiberboad Panel Triumph 8
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
