TR2/3/3A Would like a paper pattern for TR3A hood stick cover
TuffTR250
I bought a very used hood stick cover to hopefully use on my 1961 TR3A. The overall length seems to be too short for my TR3, at 69 inches tip to tip. It appears it may not actually be a stick cover for a TR3A. Does anyone have a paper pattern they can send me, or provide detailed measurements (length and width) of the different "sections" of the cover so I can compare to the cover I have? Thanks!
Bob
Upland Moss build-a-paper car contest Spridgets 1
T General Tech NOS Paper Air Filters, Shelf Life Triumph 2
T TR2/3/3A Finally found and fitted paper carb air filters on my TR3 Triumph 28
T TR2/3/3A Question on paper air filters for TR3 Triumph 3
J Axle to hub paper gaskets....are they necessary? Austin Healey 13
Zitch TR4/4A Can I use these Paper filters on my 63 tr4 Triumph 2
G TR2/3/3A paper air filter for tr3 Triumph 1
AN5Sprite Paper Bugeye Spridgets 5
F Bugeye hypoid leak from paper hub gasket. Spridgets 7
aeronca65t Paper Mustang Other Cars 2
coj Removing side curtain protective paper Austin Healey 10
N BJ8 paper or felt oil filter ? Austin Healey 2
HealeyPassion Rally seats project paper Austin Healey 2
B Sand paper by the disc? Restoration & Tools 8
HealeyPassion Work rally bumperettes project paper Austin Healey 10
HealeyPassion Driving light brackets project paper Austin Healey 2
HealeyPassion Dead pedal and pedal positioning project paper Austin Healey 3
HealeyPassion Works side vents project paper Austin Healey 13
KVH SU Carbs Paper Air Filters Triumph 4
chicken Tar paper under carpets Austin Healey 16
A Paper thin hub gasket- will it work? Austin Healey 6
nevets Paper or felt oil filter? Austin Healey 13
JPSmit Todays Paper - new MG Spridgets 14
tahoe healey back plate paper gasket Austin Healey 14
J TR2/3/3A TR3 "Near perfect" in local paper Triumph 2
JamesWilson Paper Mini, for free.... British Motor Corp 0
G Oil Filter - Paper, Felt or Convert? Austin Healey 15
aeronca65t Paper Brit-cars Other British Cars 11
J great LBC's etc in the local paper! Other Cars 4
AUSMHLY Tar-paper, Dynamat- Foil covered felt Austin Healey 23
martyc T-Series TD Oil Filter Element -- Paper or Felt? MG 2
Sherlock Wedge Interesting TR7 project car in local paper Triumph 10
Basil Saw the new C6 in the paper today - impressions Other Cars 15
78Z MGB Make your own paper MGB MG 4
algot1901 Wheels or Rims Lug Pattern Other British Cars 12
pbraun Bugeye tonneau pattern Spridgets 1
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
B Arm Rest Pattern Austin Healey 4
Kleykamp Hole pattern on spare tire lock covers??? Triumph 5
Kleykamp TR2/3/3A TR3 Door hinge hole pattern??? Triumph 12
O TR2/3/3A TR3 Wheel Bolt Pattern Triumph 1
W steel wheel bolt pattern on a 100-6 Austin Healey 3
t_bush Spitfire Spit armrest pattern Triumph 3
mgbmedic TR2/3/3A TR3 Bolt Pattern Triumph 9
W I need a door panel pattern Spridgets 3
jaegzie Close Tranny shifting pattern Spridgets 0
Magyar 62 MKII Sprite carpet pattern Spridgets 5
G MGB MGB Carpet Pattern MG 2
M Carpet pattern needed Spridgets 15
M Pattern for interior front panel. Spridgets 9
