TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil.
JoeTR3A
A friend has a 58 TR3A. He had some warm no start issues (let us not talk ethanol and heat soak). I thought possible could be the coil getting too hot increasing resistance and lowering the high volts delivered to the plugs, and adjusted the voltage regulator shutoff down a tad 1/8 turn counter-clockwise on screw thinking at high rpm could have caused too high a running voltage (this lowering was actually reversal since prior adjusted voltage regulator shutoff up opposite, 5/8 turn clockwise, according to Lucas procedure since running voltage at 3,000 rpm was way too low so battery was not charging, so originally raised regulator to 16v at 3,000 rpm as instructed by Lucas). He still had one slight warm no start since reversed a tad, but not driven much.
Yesterday tested the 1968 HA12 45208A non-ballasted coil. It was about 180°F after short ride 2 miles, mounted on side of engine, so does not say much. If he ever has a future new no warm start problem, asked him to touch the coil to see if massively hot. Checked coil readings (took several with two cheap millimeters and adjusted for calibration) and got:
2.9-3.5Ω on the primary
8.7K-9KΩ on the secondary
The secondary seems low compared to replacement DBL105 spec at 2.8Ω prim 10.45KΩ secondary, and DBL101 at 2.9Ω prim and 10.9KΩ secondary.
So it seems his coil is coming up about an Ohm and a half short on the secondary winding against replacement specs.
1.) Looking for advice. Is the coil too far out of tolerance due to low Ohms on the secondary windings that the old coil should be replaced with the DBL105? Anyone suggest or recommend that? I have no idea if this is too far out of tolerance. Or are things good to go, and do nothing?
2.) If he does replace, is it highly suggested to be better to upgrade to a ballasted coil and ballast as opposed to stock DBL105 non-ballasted?
3.) If the coil is bad, weak, would the low secondary Ohms resistance lead to higher amperage delivered and the coil getting too hot raising resistance so the high voltage jacked up coil output falls and thus no warm start (and noting running voltage off the generator is higher than battery when starting)? Am I thinking possibilities correctly or in err?
Thanks for any replies.
CJD
The usual failure mode of a coil is that the internal insulation breaks down, so that the secondary windings start jumping, or primary/secondary windings start shorting. It is also very common that early in the failure mode the coil will run fine cold, and begin to run badly when hot.
I cannot say what to do about the ohm readings. Other than helping to tell if your coils are broken (which yours are not from the readings), it's hard to tell anything else from ohming them. If you have doubt about a coil, it's best to swap it out and see if that fixes the problem.
DavidApp
Have you considered the condenser? I had a running issue that was caused by a bad condenser.
I got a new one from The Distributer Dr. in the UK. Seems there are some poorly made ones out there these days.
David
sp53
Occasionally, my tr3 has trouble starting when hot. I found that holding the gas pedal to the floor on the hot start problems helps a lot. These cars do not have accelerator pumps, so holding the pedal to the floor when starting hot only lets in more air. For sure, lift your foot once it starts. Give it a try.
Steve
Sarastro
Those resistance values are fine. Coils are not identical and I've measured ones that are well outside that range.
When coils fail, it's usually because of arcing internally at high voltages. You can't measure that with a multimeter. Coils will almost always get warm, but shouldn't be so hot that you can't touch it. The car will run fine with a "nonballasted" coil (3-4 ohms). A ballasted one will not do any better. With a ballasted coil, you MUST include a ballast resistor to bring the total resistance to 3-4 ohms, so you are just back where you started.
If you adjust the regulator, you really must do it as described in the Lucas books and shop manual. Random adjustments will just create a mess. BTW, a lot of the new, replacement regulators, especially the Lucas one, are garbage. The one I bought was misadjusted, right out of the box.
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
R TR2/3/3A TR3A Coil/condenser problem Triumph 22
Lukens TR2/3/3A TR3A coil. Correct resistance? Triumph 6
A TR2/3/3A Correct Coil for petronix ignition tr3A Triumph 2
T TR2/3/3A On TR3A what gauge wire from fuse box to coil? Triumph 17
T TR2/3/3A TR3A front coil springs - 9-1/2" or 11"? Triumph 2
6TTR3A TR2/3/3A TR3A coil Triumph 7
angelfj1 TR2/3/3A Lucas Ignition Coil for TR3A Triumph 1
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
