TR2/3/3A TR3A overdrive question
Dick Burk
I have a '59 TR3A with overdrive. The overdrive operates fine. In attached picture you see two electrical connections on the top of the transmission shell. One is the switch which activates the electric overdrive. I have no idea what the other is. A relay switch? Only one of the leads is attached to an electrical line. My TR show manual does not show more than one switch for an overdrive. Any ideas?
  • Transmission.pdf
Geo Hahn
My rebuilder wanted to be sure I understood...
DornTRoriginal
The OD unit I have does not have the switch for OD in 2nd rebuilder thinks it is not wise to use, I am tending to agree but I've never had an OD found the rebuilt one and jumped on buying it. How often is the OD used in second anyway?
Second question is how do TR3 owners check transmission oil level and re fill the transmission if you've done the conversion? The TR3 had a nice access hole and dip stick the TR 4 OD unit fills on the opposite side and it seems like an awkward situation if you are doing the routine maintenance tasks. How do you deal with this situation?
TR3driver
Great Pumpkin - R.I.P
I don't use 2nd OD every day certainly; but it does come in handy on occasion for things like driving hard on twisty mountain roads, or maximizing acceleration in a straight line. Sure, using the overdrive means it will wear out quicker; but that's true of the whole car. If you are looking to minimize your driving costs, I'm afraid you've got the wrong car. It's not about miles per gallon, it's about smiles per mile. The only problem I've had that I directly attribute to 2nd OD is that a previous rebuilder either didn't check the pressure or didn't get it high enough. But he never said he did it on purpose, just "Ok, bring it back and I'll fix it."
What I did was to transplant the shift rails and forks into my original top cover, so I could keep the dipstick. Others have drilled out the later casting for the dipstick.
But, you need to get under the car for routine maintenance anyway; so it's not that much more hassle to jack up and support both ends (to get it roughly level) and check the gearbox oil through the port on the side. Then you can grease the front suspension and check the rear axle oil (etc) all without having to move the car again. I try to go through all that at least once a year (or about 12,000 miles for me), but it doesn't always get done on time.
BTW, HF has their 6 ton jack stands priced at only $40/pair at the moment. Their 3 ton stands ($24/pair) will certainly do the job, but sometime I need the extra height.
TFB
I use 2nd od when I am trying to hold a certain speed and 1st is to high,3rd would lug.This is usually on some backroads along the area rivers scenic cruises.No way as necessary as 4od but I do use it.
I have tr3b od and had the earlier dipstick top fitted,then matched the dipstick to the level that the fill plug allowed.
Its nice to be able to fill from top while checking dipstick especially if you just want to check between change intervals but not necessary as I can pull and replace the fill(left side) and drain plugs without jacking up the car.
Tom
6TTR3A TR2/3/3A TR3A overdrive relay question Triumph 3
Tinkerman TR2/3/3A Overdrive Switch question. TR3A, Problem Solved! Triumph 10
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
T TR2/3/3A Overdrive emblem on TR3A? Triumph 25
Tinkerman TR2/3/3A TR3A Overdrive Relay Triumph 12
R TR2/3/3A TR3A Overdrive Wiring Harness Installation Triumph 19
Q TR2/3/3A TR3A Overdrive Adaptor Plate!! Triumph 1
luke44 TR2/3/3A Early TR3A Overdrive relay location Triumph 5
T TR2/3/3A tr3a overdrive vendor questions Triumph 19
deadair TR2/3/3A TR3A Overdrive Conversion Triumph 7
T TR2/3/3A Stebro Exhaust on TR3A w/ Overdrive? Triumph 10
T TR2/3/3A TR3A overdrive conversion - whats needed Triumph 6
B TR6 TR6 "A" Overdrive fitted to a TR3A? Triumph 12
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
