MGB Electrical Part Identification
Nolanshipman
I'm just starting to dig into my 70 Roadster Barn Find beginning with wiring inspections since the car was a mouse hotel for 30 years. The PO did quite a few wiring modifications - many of which have now been removed or repaired.
In removing the lower console to remove the old Craig radio, I found the power lead (yellow) for the radio terminated in this block. Based on the coloring for the other wires, this block would serve dash/cockpit lighting but I cannot locate this device in the 5 shop manuals or Rick Astley's book. It appears to be a basic terminal block but I'm having trouble validating that it is original to the MGB (though it appears to be) and what purpose it would serve now that the radio has been removed.
mezy
It looks like the back of a switch. Its next to the ciggy lighter where the heated rear screen and map light switches would be.
Perhaps a Map Light, which is normally fed from the dash light circuit so it only works when the side lights are switched on,
According to the lucas colour guide red/purple is for Switches to (map light, under bonnet light, glove box light and boot lamp) when sidelamp circuit fed.
so it would turn them all on together when side lights are on, ?
I think the switch on the right in this picture is the same as yours as you can see the red/green wire same as yours.
N
Nolanshipman
Well, I feel silly. I must have been extremely tired to have made this post. That is indeed the back side of a switch. When I went back to look at the wiring last night, I had to laugh at myself.
mezy
At least your sorted now, thats the main thing, well done for fessing up, good for the sole, :thirsty:
vping Part of my nightmare - Electrical MG 1
G I lost an electrical part...and it is NA.. Triumph 13
CARSINC Sprite Electrical System Information Spridgets 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
SNClocks Electrical Wire Lug Spridgets 2
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
F General TR Electrical parts Triumph 6
S TR2/3/3A Electrical Triumph 31
lram59 General Tech Electrical terminals Triumph 8
6 Electrical Help Please Spridgets 7
B Bugeye Electrical Diagram with additions Spridgets 6
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
KVH General Tech O/D Electrical Wire Burned Triumph 22
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
E GT6 Help electrical guru needed Triumph 4
B Bugeye Electrical Diagram Spridgets 0
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
D TR2/3/3A TR3A electrical issues Triumph 2
B Bugeye Electrical Wiring Diagram in Logic Format Spridgets 17
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
Simmo General Tech Electrical question Triumph 4
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
T TR6 72 TR6 electrical snafu Triumph 4
P TR6 Electrical Problem Triumph 26
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
N Electrical Issues Need Help Austin Healey 8
H Re: electrical short wiring damage Spridgets 11
I Bugeye electrical questions Spridgets 17
N Electrical Troubleshooting Advice Needed Spridgets 6
steveg Electrical sleeving Austin Healey 11
N TR6 Electrical Issues Triumph 5
N Electrical issue. FORUM Navigation Questions 2
C Ghost in the electrical system Austin Healey 51
S TR2/3/3A Electrical Issue Triumph 40
KVH General TR Steering Shaft/Column Short Circuit?--Electrical Issue with Light Switch Triumph 3
6inline Electrical gremlins giving me fits Austin Healey 18
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
R TR2/3/3A Early TR3 electrical system Triumph 12
K TR2/3/3A More electrical....the Starter? Triumph 8
S TR4/4A Electrical wiring tips Triumph 2
K TR2/3/3A More electrical....the Starter? Triumph 5
B TR2/3/3A Electrical Problem Triumph 13
T TR2/3/3A electrical oddity Triumph 7
L Should I do it?? [electrical conversion] Austin Healey 24
