TR2/3/3A Early TR3 electrical system
RaphaelG
Hi All,
I am starting restoration of my 1955 TR3.
Made on the 20th october 1955 is was dispatch new to Germany with a miles/h tacho.
I bought it here in France where it was imported from the USA.
It has a strange relay/fuse box that I cannot identify and I cannot understand the role of it as it is not standard.
I am attaching picture.
It may link to the very unusual overdrive switch (picture attached too)
I need to understand what is the role of it as I will rewire the car.
Thank you for your help.
Cheers
Raphael
NutmegCT
Hi Raphael. Welcome to BCF.
I can't help on your question, and my TR3 was a 1959 model. Do you have any documentation on your overdrive system?
I'm certainly looking forward to learning the answer on your mystery!
Tom M.
TexasKnucklehead
Interesting. Certainly not stock.
Does the box contain 4 separate relays, or is it a mechanical stepper/timer? I can see 2 plugs on the box, but it looks like something out of an old pinball machine.
Does 2 wires or 4 go into the shift lever? Is the little red button on top of the lever connected to the two wires?
My guess is the box is something other than the OD function. You may have to get an ohm meter and figure out where some of those wires go.
Welcome to the club.
R
RaphaelG
Thank you for your answer.
it looks like a relay box. You are probably right and has nothing to do with the OD
The OD has 2 wires (adding a pic too).
So the relay box could it be a timer for the wipers? There is no additional electric equipment on the car (lights, stereo etc..)
Small detail : cannot meter or check as I cut the harness (i know i am a bit stupid here).
TexasKnucklehead
OK, the solenoid needs one power wire, and a ground but your picture seems to have more heavy wires than needed. Generally small wires (like the ones in that relay box) run from switches or controls to a relay, which handles the higher power requirements of the device (like the OD solenoid). Unless there is some other type of wiper motor installed, I would not expect that relay box to control the wipers. The original wiper motor is ridiculously slow, so to add a control to make it slower, or even delayed, is just crazy talk.
I was asking about the wires in the first picture. It appears there are 2 at the front and 2 at the rear. I assume they go up into the shift lever and to a button on top of it, but have no idea. They may be just two wires that happen to go there on their way to something else. Maybe he added a 4-way flasher? or a 'lock-out' feature for the OD?
Even tho you cut the wires, you can follow their path and see where each end is connected. That might give a clue of the intentions of the inventor.
Tr3aguy
So is the plan to keep it stock and reuse the system you have? Some folks reorder the original wiring looms and keep it stock! Other decide to go with a more modern setup that has fuses to update it a bit, such as this link.
https://www.britishwiring.com/category-s/141.htm
Welcome to the classic car restoration thing
R
RaphaelG
Thank you for the link. I've decided to keep the wiring looms stock but clearly there is advantages to add safety with extra fuses in case of additional electrical components..
Need to re assess
TRopic6
TexasK may be onto something. Early MGAs used multiple relays to get stop & turn signal functions from the same bulbs. Does your 3 have the single center stop light? Maybe it gets the turn signals to act as stop lights somehow, along with an emergency flasher capability?
Jeff
sp53
I thought John(CJD) would know what it is because he has a 1955 also, and did a complete restoration with amazing documentation and research; you would do well to check it out. I have heard about people putting the OD switch in the shifter, but never saw it before. I like it-- kinda 007 stuff. Where is Randall when you need him; he must have bought a Jag too. Anyways there just not that much electrical in these cars, most everything is mechanical. Perhaps it is a clever way to shift in and out of gears on the OD. The picture is too small to see well.
Steve
CJD
Well, I have no idea what the white box is. What I can tell is that the original overdrive relay is still attached to the bottom of the battery box, but it is gutted. It's just an empty shell. All the extra wires appear to be related to the overdrive switch being moved to the shifter knob. It appears the PO simply tapped into the overdrive harness in the same location as the original switch, left of the steering column...and then ran the 2 extra wires over to the shifter. Thus the extra wires , which are very neatly bundled. It could have been accomplished with far fewer wires, but not any more neatly?!?
Since the overdrive relay is gutted, I would imagine the white box has something to do with that...but without a closer picture I can't tell what's going on with it??
PS..Randall must have gotten locked of this forum again. He is still active on the "other" one.
Sarastro
Those are old-style relays in the box. They could be for almost anything, but likely for headlights or some other high-current things.
People add all kinds of electrical stuff to these cars. Often, it is just not worth the effort to figure it out. Sooner or later I think you will want to remove it anyway, and either return it to stock form, or install something more sensible.
Here's what my TD looked like when I received it. No way was I going to try to sort out that mess! I just ripped it out and installed my own circuitry, including a box of relays for lights and such.
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R For Sale 1956 Early small mouth TR3 Triumph Classifieds 1
jfarris TR2/3/3A Uh Oh - will these carbs work on an early TR3 Triumph 4
jfarris TR2/3/3A Installing replica Brooklands Areoscreens on early TR3 Triumph 4
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
K TR2/3/3A TR2 early TR3 windscreen stanchions Triumph 1
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
M TR2/3/3A Which frame is correct for early TR3 Triumph 18
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
M TR2/3/3A Who sells seal for early TR3 hardtop? Triumph 6
Marvin Gruber TR2/3/3A Early TR3 wire wheel set up. Triumph 9
T TR2/3/3A Early TR3/4 trans help needed Triumph 7
M TR2/3/3A Rebuild early bomb style starter TR3 Triumph 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
drooartz MGB Early tail lights on later car MG 17
T Wanted: Early BN1 Sidescreens Austin Healey 2
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
J Early BJ8 Armrest Latch Austin Healey 2
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
