TR2/3/3A Rebuilding the early tr3 starter
sp53
Rebuilding the early tr3 starter. The sleeve assembly on my early starter has failed in a way I have not experienced plus I recently rebuilt it; the little ears on the rubber drive piece wore down or fell apart rather than the vulcanized rubber shearing. The little ears on the aftermarket part look like softer metal than the old ones. My worry is if I replace the rubber sleeve with another one, I will have the same problem. Perhaps there is more detail picture somewhere on how much play if any should be in the whole moving drive assembly. I did crank with this starter more because this is the engine where the cam failed, and it took me some time to figure things out, so maybe a rebuild would do it
It appears as the system engaged the rubber drive, it gradually wore down the corners of metal on the rubber drive and opened up the drive assembly enough so the ears could push away the drive rather than stay keyed in place and lock the drive. Maybe more brass washer shims or a stronger internal spring would hold it tighter together and stop any unwanted twisting.
I imagine the aftermarket drive sleeve assembles are all manufactured in the same place because the market is so small. I guess I should get the best deal money wise on the sleeve and move on from there. Perhaps there is a way to hold the old assembly together better. The parts have worn nicely over the years and perhaps that wear is the problem. John rebuilt one years ago so his pictures should help. Anyways, I really do like how those old starters are put together. I came by a high torque in my travels, but I believe it fits a tr4
Thanks steve
S
sp53
i move to my back up early starter which worked briefly, and I am doing research on these old early starters using the Bentley book which states to use paraffin on the drive and to have NO dirt. There was some blackening on the drive from old oil, perhaps oil?. The drive did not want to come out the last ÂĽ inch to push back on the first spring of the assembly, and it did work briefly, but I am not sure it needs to move to the end. It looks to me like that might be the problem with the drive, but taking the starter in and out to test is real work. I put WD40 on the drive and worked it-- in and out ---and it seems to work better.
I guess paraffin is wax and oil that does not attract as much dirt as oil. The drive I am working on has the rubber sleeve still volcanized but the starter stopped engaging. It sounded like the rubber sleeve had spun free, but no. I am thinking now maybe I did not test the solenoid correctly. There is an old school starter place in town that does big rigs and small stuff. I kinda hate to bug them, but this knowledge is becoming esoteric.
The painful part is when the solenoid, battery, starter problems comes up, I have not been sympathetic enough on the diagnoses to others—karma
Steve
DavidApp
Paraffin in the UK was used in heaters and lamps so it is probable similar or the same as Lamp oil. We used it to clean bicycle chains and bearings.
David
S
sp53
I put my back up starter back together and installed it with a known good solenoid and the engine turned over briefly for a couple revolutions. This leads me to believe the field coils are giving resistance to the starter motor mostly because there is some rust in behind the cotton windings. the good news is I think the drive is good. When I got this starter it had recently been rebuilt, but probably back in the 1980s because the tabs on this barn find car where from 1980. Who ever rebuilt it welded the big Phipps screws to the case, so I will need to grind the screws out. They used new or rewrapped coils. The outer cotton looks new, but the back side of field coil cotton perhaps has rotted and grounded because I can see some small deep rust spots.
I took an ohm meter and walk around the armature shaft with no shorts (maybe that is growling).Next I tested the drive by twisting on the assembly to make sure it locked one way out. Then I took the field coils and case from the other starter and moved them to this starter. Today I plan to install this new combo of starter parts and see if it starts……… Also, I will do a test on the coils of the back up case with an ohm meter for ground and a test light to see if the circuit is complete between the coils.
thanks steve
S
sp53
Well I am one happy guy; I combined the starters and came up with a good one for today anyway. Heck I only have 98 miles on the rebuild of the car. Anyways, the starter in the picture came with the car and was a fresh rebuild, kinda col I thought because this car sat for 40+ years. However, they never painted the inside of the case and bare the metal rusted to ground. The armature seems to fine. I could use a new drive gear. I used to see them on eBay and Moss used to sell them. I talked to the guy at BPNW who seems very knowledgeable. He said he stop selling parts for boom shell type starter because most the parts are not available plus people had problems getting a good rebuild because of the parts.
steve
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
bighealeysource Rebuilding BN2 generator Austin Healey 5
Xte Rev counter rebuilding ... Austin Healey 2
J TR6 rebuilding tr6 rear hubs Triumph 13
H head rebuilding mods Austin Healey 15
