Rebuilding the Dip Switch
steveg
My old one died last year; my new one died this year - will see how long the rebuild lasts.
Picture story: https://www.pbase.com/stevegerow/dimmerswitchfix
roscoe
I salute you for taking the time to fix something that anybody who helped design probably would have said "when it breaks (and it will) they'll be cheap and people will replace them". I will always spend a dollar to save a dime if I can. Makes you feel like you've outwitted the engineers. Thanks for the pictures. May your headlamps always dim when necessary....
steveg
steveg
Buying a new one wouldn't necessarily solve the problem: It failed too quickly due a design weakness where the post is riveted to the cup. I'm hoping this one will last indefinitely.
RAC68
Steve,
Good show. Jon, I very seldom look to replace if at all possible for 2 major reasons:
1. Today's parts are commonly not produced with quality and, as Steve new piece showed, will not have good longevity.
2. A failing part is my signal to dismantle, see how it works internally, and what it will take to FIX.
The second point is an integral part of my interest and what keeps my Healey active in my mind. Additionally, I have found most original electrical parts are not hermetically sealed and can often be fixed (even on the side of the road).
As an example, In 1965, while driving my Healey on a dark night through Pennsylvania's Pike County Reserve on my way to visit my girlfriend (later my wife), my headlights and connected driving lights suddenly went DARK. Faced with a total loss of lamination on a deep forest 2-lane roadway (1 lane in each direction), I pulled the car onto the shoulder, turned off the battery switch, retrieved my flashlight (torch) from the glove box, and began to look for the issue. Although disconcerting, I quickly found the innards (springs and mechanisms) of my light switch scattered on the passenger floor with the back dangling from the wires and the toggle still in the dash. After removing the rest of the switch from the dash and with my flashlight propped, I reinstalled the springs and internal components back into the switch, pressed the back on and installing a little tape for added support. I then refitted the switch back into the dash and connected the wires. After turning the battery switch back on, I started the car and flipped on the headlights and was back on my way. All this took less then 15 minutes and the fix lasted at least 15+ years before cleaning all switches and apply dielectric grease as part of a redo of my Healey (completed in 1989). This same switch is still in my dash today although I have installed a number of relays to diminish the level of power it and the original wiring are required to handle.
Jon, I enjoy this Forum and our discussions as all participants seem to posses and present creative and ingenious approaches toward the resolution of non-unique issues. Don't misunderstand, I believe we all will Purchase when we can't fix but first try.
My thoughts.
Ray(64BJ8P1)
blueskies
A similar experience here. Recently, the outer sleeve came loose from the dimmer switch, after the rivet/expanded metal let the sleeve slide past. After further disassembly, I drilled a hole in the end of the stem and used a self-tapping screw (maybe with a small washer and a drop of JB Weld - can't say for sure). Anyway, it seems stronger and less likely to fail than the original assembly method.
Billm
Did you add headlight relays? With lowered current going through the switch it should last a lot longer (that is what I did after I rebuilt mine)
BillM
steveg
steveg
BillM
I have headlight relays. The problem for me was that the rivet failed, not electrical failure. The copper contacts inside the switch are completely clean.
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
bighealeysource Rebuilding BN2 generator Austin Healey 5
Xte Rev counter rebuilding ... Austin Healey 2
J TR6 rebuilding tr6 rear hubs Triumph 13
H head rebuilding mods Austin Healey 15
