General Tech Rebuilding the Engine
KVH
I'm rebuilding my TR4A engine and I'm trying to recall some basics. It seems I can't check crankshaft end float until after I torque all three of the main bearings and then, if the end float is wrong, I'd need to loosen the center main cap, remove the thrust washers, and repeat it all over again each time I check or recheck. Is that correct? Also, as for plasti-gauge, it seems I'd have to torque all three main bearings and then loosen and repeat all three if I needed a different undersize bearing. Am I recalling things correctly. Finally, what kind of assembly lube do you suggest? Some folks say white lithium grease, some say simple motor oil, and others prefer a professional grade grease "labelled" as an assembly lube.
Platinum
Yes.
Yes.
White Lith will work if the engine will be installed & run in soon after rebuild. It tends to 'dry out' over time.
"Red Line Assembly Lube" would be better short term, but any of the sticky synthetic red grease lubes would work.
Sarastro
Yes, that's basically it. If the end float is off, you can get thrust washers of a different size. But they are in 5 mil increments, as I recall, and the spec is 4-6 mils. But in the table on p. 1-104 in the shop manual it says this is "desirable," whatever that means. Just get as close as you can.
You can get bearings in 10-mil increments, but the clearance is specified at 1.5-2.5 mils. If a clearance is off by, say, 1 mil, a different bearing obviously won't fix that. The plastigage is mainly valuable as a check, to be sure all is in order. If you miss the clearance spec, you need to start measuring and see where the problem is.
Hap Waldrop, who hangs out in the Spridgets forum, is a high-end engine builder, and he strongly recommends molybdenum assembly lube. You can get it anywhere; I got mine from Napa. A tube of it will last through several engines.
KVH
KVH
I'm having a problem with what I'm seeing in the rear main seal installation instructions. This is my viton seal after-market one. The statement is very clearly made that after bolting the two halves of the aluminum seal to the block and rear main cap, with the bolts not fully torqued, you are to tap the halves further toward the centering tool to assure proper fit, and then fully torque the halves. The tapping presumably is to adjust fit in case there's some play through the bolt holes or otherwise. After tapping, you torque. This seems to make sense until you actually try it. The two halves are perfectly mated, and tapping one just impacts and moves the other. It sure seems to me that unless you're dealing with something really sloppy in the manufacturing of the seal halves, there's no sense in tapping either half. If they mate together around the centering tool, you should be done. If you tap, rap, or bang, assuming there's some nominal clearance, you're just moving both around for no purpose. Am I missing something? I'm open-minded, just puzzled. (He says while holding his big tapping hammer).
DavidApp
It may be a poorly worded instructions.
I seem to remember the centering tool was clamped tight by the main bearing cap. Holding the Seal halves as you tighten should do it but Light taps may help keep the halves in close contact with the centering tool just in case the halves move as you tighten the bolts.
David
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
PATR8 Finally rebuilding the 8 engine Triumph 4
I TR6 69 TR6 engine rebuilding basics advice Triumph 14
davidk TR6 Rebuilding TR-6 Engine - Questions, Questions... Triumph 14
T Best book / primer on Triumph engine rebuilding Triumph 2
JamesWilson Rebuilding Lotus 907 Engine Lotus 17
Michael Oritt Book on engine rebuilding Austin Healey 4
71tr TR6 TR6 engine rebuilding sources Triumph 4
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
