TR2/3/3A Rebuilding SU carbs 1960 TR3A
Tinkerman
Looks like I need to rebuild my carbs for the 1960 TR3A post 60,000 commission car.
I have rebuilt any number of carbs over the years but never any SU's. I would like some help in picking the right kit to buy and would appreciate any tips and suggestions about doing the job.
My carbs were professionally rebuilt by a company on Long Island, but I did a NO-NO by running the engine about 4 years ago and not running the engine empty of gas. It has been sitting for about 4 years and will not start. I have tried all of the normal items that cause a heart attack on engines BUT cleaning the carbs. Thought I might get away with just a spray cleaning but it didn't work out. Now it has to be a take apart cleaning, sigh...........
Anyhow what kind of kit do I need, bought from whom and any other thoughts and/or suggestions GREATLY appreciated.
Thanks, Dick
DavidApp
Hello Dick
The SU carbs do not have all the small passages and holes that can get gummed up on other carbs.
As they were rebuilt professionally you may get away with removing the tops from the float bowls, cleaning the bowls and checking that the float needle valves are clear of goo.
Also flush all the old gas out of the system all the way to the connection to the front carb.
Davd
TR3driver
Great Pumpkin - R.I.P
IF it's just a matter of cleaning, then just a gasket kit will do. Sitting for 4 years, even with old gas, shouldn't wear the jets or throttle shafts, or float valve.
In fact, being something of a cheapskate, I would probably just pick up some O-rings for the jets, and only remove the jets and jet housings for cleaning. If they are blocked, that's the most likely place, and although it's a bit fiddly getting enough linkage out of the way to pull them out, IMO it's a lot easier than removing the carbs from the engine. The cork gasket at the top is almost always reusable, and the metal gasket inside should be fine, so the jet seals (which were originally cork) should be all you need.
But I'm also dubious that that is your problem. Will it fire and die if you squirt some carb cleaner down each carb throat? If not, your problem isn't lack of fuel. If you take the float bowl lids off, do they have fuel in them (float near the top) ?
TomMull
I know of another instance where newly rebuilt carbs had fuel inlet valves stuck shut after sitting for a couple of years. Tom
R TR2/3/3A Rebuilding H4 carbs Triumph 8
glemon Rebuilding stromberg Carbs Throttle Shaft Bushings Triumph 6
D Rebuilding the SU HD8 carbs Austin Healey 24
eejay56 Rebuilding SU carbs Triumph 16
Tinkerman Rebuilding SU carbs Triumph 4
J rebuilding carbs. Triumph 2
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
