SteveBones
The like both driving and working on my Triumphs. I am considering whether to rebuild my TR3A transmission (non synchro first) vs having it done by a professional.
Condition of the Transmission
The biggest issue is the size of the oil leak from the front seal. The car had been sitting for 10 years. Also, the clutch is engaging very late so it needs to be replaced soon. The transmission also requires slow and deliberate shifting to prevent grinding between gears. Otherwise the transmission works fine. No major problems other that what seems to be seal and maybe synchro wear.
No Previous Experience But..
If I try to rebuild the transmission myself, it will be the first time. I am becoming interested in the idea after going through the documented rebuilt phase 1 and 2 publications on the VTR website. Though from the Triumph manuals, there are a list of various Churchhill tools listed for the job, from the Triumph Transmission Phase 1 and 2 documents it looks like I will only need a piece of angle iron for removing the rear flange, and a bearing puller in addition to my regular tools.
What do I really Need?
I wanted to ask for your thoughts on rebuilding the transmission myself based on likely needing to replace seals, bearings, countershaft, and synchro's. I am expecting this to be a 6 to 8 hour job (not including the removal and installation of the transmission itself). Is this a reasonable expectation? Are there other difficult to find or expensive tools required?
Any feedback based on your own experience is greatly appreciated. I am interested in the idea of rebuilding a transmission at least once if it is not a major time sync or headache.
Thanks,
Steve
Thanks,
Steve
