Ribcase transmission won’t engage 3rd or 4th gear
N
NedZ
I have recently bought a 1967 Sprite that was in storage for about 20 years. I do not know why it was not used. The 1098 engine runs pretty well and I can shift into 1st, 2nd, and reverse with no problems. When trying to go to 3rd or 4th the selector rod does not move at all. It may be that the interlock ball or plunger is stuck.
Is there anything that can be done to free this without pulling the gearbox out of the car? Is there anything else I should check?
Boink
Bronze
Of course, always check the hydraulics... but if you can get it into all but 3rd and 4th... um, not so good.
[I hasten to add that I don't know that much about transmissions except to pull them and take them to someone that does.] :smile:
Platinum
Have you taken off the shifter boot to be certain the gearshift lever travels as far to the right as it should to shift through the 3rd/4th position and not stopped by the tunnel's opening in the body?
N
NedZ
The gearshift lever will go far enough to the right to engage reverse. That is actually past the 3rd/4th position in this case.
The transmission had a loose drain plug and no oil when I got the car. Shifter seemed “gummy” at first but has gotten better now that I have oil in it.
Platinum
Apologies. Been literal decades since I've seen a Spritdget with a "right-side" reverse. You stated the engine runs, so have you filled the gearbox and run the thing up to normal temp? For what its worth, (as in not much to lose) maybe try a half-n-half trans lube mix with ATF? If the spring/ball/rod were somehow stuck due to corrosion or "goop", that may loosen it up with operating temp and ATF mix. But it sounds ominously like an engine/gearbox R&R in your future.
N
NedZ
Tried the ATF mix you suggested and ran about 30 minutes. No luck with 3rd/4th gear. Also, the more I run the car and fight with the trans, the less I like the sound of the clutch release bearing. I guess 20 years of inactivity was harder on this car than I had hoped!
Making plans to pull everything out. Thanks for trying.
RickF
Can you shift into 3rd and 4th with the engine off? If so, do it a bunch of times to try to loosen up the interlock parts. probably pretty gummed up after 20 years with no oil.
N
NedZ
No difference in the feel of the shift lever with engine running or not. It seems to go into the middle slot easily but there is just no movement forward or back and I am pushing pretty hard.
Platinum
Too many of the internal bits of that transmission are hens' teeth to be forcing things. Time to pull the engine and box to truly ascertain what's wrong.
N
NedZ
I now have the engine/transmission out of the car. The clutch release bearing is completely disintegrated but that will be easy to fix. The third/fourth shift problem appears to be a stuck “syncro assembly, 3rd/4th” Item 14 in the Moss catalog. There are no real signs of distress anywhere but the outer sleeve cannot move at all on the splines. Slight movement is possible on the selector fork for 3rd/4th and the rest of the gears engage normally.
I am not going to disassemble further until I can locate a replacement part.
In the meanwhile, I am wondering if there is someone who has seen this part get stuck and hopefully has a way to free it up.
Platinum
If the thing sat static all that time, possible corrosion in one or more of the detent springs/balls would be about the only thing to keep the sleeve from moving. Disassembly and soaking the 3rd/4th cluster in ATF and periodic "persuasion" with a dead-blow hammer, or a piece of wood as interface with a Big F'n Hammer in both directions should get it apart eventually. Patience and persistence! If you can get it to move at all, the back-and-forth (one side, then the other) impact should work.
A "last ditch" effort may be to dilute muriatic acid and give the assembly a couple hours' bath. But safety is a real concern with that! A super-thorough water rinse and the cog back into the ATF as well.
JPSmit
while you have it apart, confirm that the pivot arm isn't bent - they are a known weak spot.
JPSmit
Thanks. Will update in a couple days.
Sounds great! Not wanting to complicate your day (and remembering that I have a 1500 not a 1275) there are real issues with certain clutch throwout bearings.
PAUL161
Here's my 2 cents on throwout bearings. The roller throwout bearings need a slide tube on the front of the transmission to keep them straight and in proper alignment with the pressure plate. The carbon throwout bearing will follow the line of the pressure plate rubbing surface and is not designed to need a slide tube. Carbon throwout bearings can last a very long time, even if one is lax in not putting the transmission in neutral at times for a long period. Yes, there are some who say they have X thousands of miles on roller bearings with no problems, if that is true, why does replacing a carbon-bearing with a roller/ball bearing cause the roller to go bad so quickly, because they weren't designed as a replacement. Use what the factory-installed, carbon, they had a good reason for doing it their way. I have a carbon throwout bearing with my new 5-speed High Gear transmission and it works perfectly!(y)
Platinum
We've always stayed with rock-stock clutch T/O bearing and PPlate in any of the clients' BMC/BL cars. The bearing style, as Paul notes, is meant to be centered and in plane with the pressure plate by means of a tube surrounding the tranny input shaft. No tube means the bearing hits the fingers of the plate at one point on its circumference, chewing it up prematurely.
The Sachs or AP "kits" have been good in the past, it's possible that has changed but more recent experiences need be posted.
N
NedZ
Thanks for the valuable input regarding throw out bearings. I will be staying with the original style carbon bearing.
The stuck parts in the transmission have yielded to spray penetrating oil and a three jaw puller. The corrosion cleaned up well with a wire brush and I will be able to re-use all the gears. Will replace balk rings and needle bearings. Hope to get all the detent balls in the correct locations.
N Sprite "Ribcase" Transmission Austin Healey 3
TulsaFred 1275 Ribcase transmission in Bugeye - Which slave and pipe? Spridgets 23
S Ribcase transmission needed - Chicago area Spridgets 2
DanLewis 1275 engine and ribcase transmission $750 [NFI] Spridgets 0
L Ribcase transmission with 948 engine Spridgets 8
drooartz Checking a ribcase transmission Spridgets 2
drooartz Shipping a ribcase transmission Spridgets 17
A Ribcase transmission Spridgets 0
T Ribcase Shift Lever Installation -Bushing Spridgets 1
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
J New Guy 948 ribcase question Spridgets 6
S Ribcase versus Ribcase Spridgets 1
AHS What speedometer gear is needed for a ribcase in a Bugeye? Spridgets 6
TulsaFred Starting Ribcase rebuild Spridgets 15
Rut Ribcase Spridgets 3
N Ribcase Ratio's Spridgets 8
Gerard Laygear thrust washer for ribcase gearbox Spridgets 5
bugedd Thinking about rebuilding my ribcase Spridgets 16
D Best manual for ribcase rebuild? Spridgets 6
smaceng Ribcase rebuild help Spridgets 0
J Ribcase first gear hub Spridgets 2
drooartz Ribcase tranny - painted or bare? Spridgets 7
58Custom Who sells best ribcase rebuild kit? Spridgets 6
64rocksprite Ribcase - all the same? Spridgets 4
drooartz Bugeye shifter on later ribcase Spridgets 3
Sarastro Question about ribcase trans and clutches Spridgets 9
T Ribcase Input/First Motion Shaft source Spridgets 2
ChrisS Ribcase split washers Spridgets 1
ChrisS Ribcase slave cylinder Spridgets 0
Prince_Phillip Rebuilt ribcase for sale. Spridgets 1
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
