TR6 Installing differential and transmission
ahfan
I have a newly rebuilt diff and trans. I don't have the time to install them. Just wondering what is a reasonable time for someone to install them for me? 8 hours, 5 hours?
Gliderman8
Having done both I would lean towards the 8 hours and possibly a little more. Don’t forget the driveshaft also has to be installed as well as possibly removing and reinstalling the interior if you choose not to pull the engine/transmission as one unit.
Not a hard job but labor intensive in my opinion.
A
ahfan
Is this a re install of the original gearbox and diff, or have you bought them to fit into an untouched car?
Same ones that he took out. Took him 20 mins to take out the diff and took me 30 mins to take out the trans. There is NO WAY it would take an experienced mechanic who does nothing but TR6's to take more than 8 hours to install - simply bolt on - these 2 items. NO WAY.
Tybalt
You weren't really clear on the circumstances of the work and times were based on a standard R&R of the units. Given your "NO WAY" thought, would we now be correct in thinking that the interior is out of the car, tunnels removed, etceteras and so on? If that is the case and assuming that it is a non OD box, it will be less that 8 hours. The other consideration would be if you need the half shafts installed as well plus on an OD box, any set up and adjustments that must be made for the OD unit.
At the risk of asking the proverbial silly question, have you talked with the mechanic that removed the diff about doing this work for you and what that mechanic would charge?
A
ahfan
The OD would make no difference. It is a new rebuilt trans with an OD. It simply has to be bolted up to the engine. All interior was removed. It is a straight bolt on job. It's just ridiculous to say that bolting up a diff and trans takes more than 8 hours.
Madflyer
Having done it both ways interior and no interior and no lift. 3 HR and I did it alone. The Diff is a bit of a bitch lining up and jacking it in at the same time. Transmission with seats out and motor in not to bad either. I do not use air tools so all bolts by hand.
Madflyer
Geo Hahn
Spoken like a man who hasn't done one. The additional weight, width and tail-heavy balance of the OD makes the task much more difficult solo. It also has some bits (e,g, linkage below the solenoid) that can want to foul on the floorplan - requiring more wrassling.
'Simply' - I like that. I never had one go straight on, always some finagling and rotating to get into position to clear the sheet metal.
Popeye
Bronze
This might be hard to find - there are a few dedicated Triumph specialists (Macy's, etc.), but not enough Triumphs around to support many specialists. More than likely you'll find a quality mechanic who does all sorts of older cars - and may spend some time figuring out the nuances of each car before starting the job.
Hamish Racing
If you are so definite - I’m not sure why you asked the original question?
If it came out so quick for someone get them to put it back in.
M TR2/3/3A Installing new gasket on TR3 differential cover Triumph 13
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
S Installing a Radiator Fan Austin Healey 9
G Installing New Rocker Shaft Assembly Austin Healey 3
W Need advice on installing new side curtain glass Spridgets 1
Bayless Help please installing bonnet release cable Spridgets 8
M TR6 Installing Retrosound? Triumph 4
S TR2/3/3A Installing the distributor pedestal. Triumph 3
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
Z Installing Toe Board Panels Austin Healey 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
B Installing cam bearings 1275, can I do it? Spridgets 1
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
steveg TR6 Installing adjustable trailing arm brackets Triumph 7
T Installing Garmin GPS in a BJ7 Austin Healey 19
F Installing AC in my 1960 Healey Austin Healey 14
S TR2/3/3A technique for installing a door Triumph 5
R TR2/3/3A Installing wiring harness in steering column Triumph 59
R TR2/3/3A Installing gas tank Triumph 6
C Installing rubber grommets in firewall? Austin Healey 6
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A installing the wiring harness Triumph 8
R Installing Sprite Luggage Rack Spridgets 9
Lukens TR2/3/3A Installing a throttle. Triumph 2
J Powertune booster for a bj8 , trouble installing Austin Healey 2
B TR2/3/3A Installing dzus fastners in bonnet Triumph 8
D Prepping Floors Before Installing Interior Restoration & Tools 6
drooartz Installing front hubs, tips? Spridgets 15
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
K TR2/3/3A Installing Moss wheel spacers? Triumph 5
D BT7 tri-carb installing my crank Austin Healey 4
aero3113 Installing Front rotors to hubs Austin Healey 2
C Advice for installing a 3000 Grille??? Austin Healey 7
B MGB Installing new upper fulcrum bushings MG 5
B MGB Installing upper fulcrum bushings MG 0
S TR4/4A procedure for installing gauges etc Triumph 0
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
55modified Help installing toggle dip switch on dash for lights. Austin Healey 23
TRMark TR4/4A Installing a new windscreen Triumph 9
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
T Installing a Lucas 16 ACR alternator on Bugeye Spridgets 10
KVH General Tech Installing the Pistons and Rings Triumph 7
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
T TR4/4A Installing wheel arch covers in a Tr4a Triumph 0
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
