BT7 tri-carb installing my crank
  • Thread starter Deleted member 21878
  • Start date
going out today to finish installing my crank. i have been putting this off because it was so cold. i wanted to wait until i could get the block, crank and garage all to the same temp.
yesterday i cleaned out the crank ports, install the top half of the bearings and set the crank in. also installed the top half of the thrust bearings. then i realized i did not have thin enough feeler gauges to check the end play. so i need to get a set today. also popped out the old pilot bearing and installed a new one.
then i came in and made a checklist/procedure to install the bearing caps. i figure i will break down this build in to small jobs and do a procedure for each one just before i go out to do that part. a good way to review. when you don't do builds on a regular basis it is easy to get excited or just plan miss something.
my main concern for today is the 1st and 4th bearing and sliding them down in to place. don't want to scratch or nick anything in the process. they were very tight coming out. so not just sure how i will get them in at this point. other than that i feel i am ready to go, once i get some feeler gauges.
since this is my first Healey engine please chime in with any suggestions you may have on this step or anything i will have coming up. next i plan to install the rear plate so i can get the block back on the engine stand. then the front plate and on to the pistons. my main and rod bearings are .010 over.
I don't think you'll get satisfactory results__if any at all__trying to measure endfloat with feller gauges. That operation is typically done with a dial indicator (even if you used a cheap one...).
crank is in and rear plate is on. also got the engine on the engine stand. things went well. i thought it would take a lot longer than it did when i started. the extra time to plastigauge the main bearings was not so bad.
i will check the run out again tomorrow with my dial gauge. i was going by how i have seen it done and always done myself.
i have found it is handy to keep some lacquer thinner around. good for cleaning up surfaces for sealant as well as the wax left from the plastigauge....
tomorrow, after checking runout again, i hope to put on the front plate and gap the piston rings. if all goes well i hope to have the pistons in the cylinders by the end of the day. if not i got the next day... great thing about being retired.
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D 62 / BT7 tri-carb engine Austin Healey 16
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
D BT7 Tri carb Backfire Austin Healey 2
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
J BT7 Hardtop Crosspiece Wanted Austin Healey 5
M Wanted WANTED: Hardtop (Factory) for BT7 Austin Healey Classifieds 6
kodpkd 1961 BT7 engine oil Austin Healey 31
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Healey 3000 BT7 rear panels Austin Healey 0
D Gearbox Dipstick (BT7) Austin Healey 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
D Rear Seat Side Panels, BT7 Austin Healey 3
F BT7 Stalling Austin Healey 9
apbos BT7 Hardtop For Sale Austin Healey 0
D BT7 Grille Attachment Austin Healey 11
D BT7 Choke Assembly Austin Healey 18
D BT7 Rear Side Panels Austin Healey 0
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
Healey Nut BT7 Windscreen Pillars Austin Healey 4
Fanch00 My 1960 BT7 History Search Austin Healey 1
Healey Nut BT7 Parts Identification Austin Healey 3
MadRiver BT7 Wiring Diagram Austin Healey 4
Healey Nut BT7 Panhard Rod Austin Healey 28
Healey Nut BT7 Rear Suspension Austin Healey 15
J Attaching BT7 Dash Facia Panel Austin Healey 2
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
R 3-point seat belts on late production BT7 MKII Austin Healey 7
T BT7 throttle relay levers short and long Austin Healey 2
C 1960 BT7 Thoughts Austin Healey 14
Lin Tach drive housing for BT7 Austin Healey 4
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
T BT7 Hardtop Restoration Austin Healey 6
dougie BT7 Video Austin Healey 8
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
B BT7 Door Seal Installation Austin Healey 13
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B BT7 Grille surround Austin Healey 9
