Cold air box for Tri Carb 3000 BT7 ???
CASCADEWILLY
Member
Ok, I have a question and have been gone for a while from this forum. I have been burned out on this project for a while and I am trying to revive myself. I have a 1960 AH BT7. I have put a tri carb set up off of a 1962 3000 on it. I have had the car since 1972. I want something different, but functional. I am a fabricator/welder ect. I was wondering if anyone out there has ever seen a cold air box on a 6 cylnder Big Healey before. If so please send links or pictures or technical or tuning information as well. PRO's and CON's are welcome. Thanks in advance.
GregW
Randy Forbes has a cold airbox of sorts with his tri-carbed Webers. A search here should turn something up.
Keoke
HI Cascadewilly, I think Greg is telling you to search through the archives of this forum.--Fwiw--Keoke
GregW
Hi Willy,
Well there hasn't been any threads I found since you started THIS thread four years ago, but Randy's photo is in there. Maybe someone has made one since then.
cascadewilly, failing the pictures from randy you could get a very good general idea how the cold air box is rigged by searching "100m" specs. or "austin healey 100m authentication", or find pictures of a "100s" engine compartment, these as im sure you know are 4 cylinder cars.
C
CASCADEWILLY
Member
I actually used to own a 100M. I bought it for $1450 back in the day ( So Cal ) and fixed it and sold it that summer for $2800 to a guy in Denver....now you know my age.......anyways I just wanted to see someones idea of one. I will probably do my own anyways. Thanks
Cottontop
Chris Kellner, here in Dallas, has built a cold air box for his RHD Rally Race Car .
Here is a picture of the box with the carb enclosure top removed, but you can see the ductwork under the Webbers and on the far side of the radiator. There is a black blockoff plate over the hole in the shroud strut. There are also a couple of pictures in the write-up at the RHD Rally Race Car link above.
If you are interested, I'm sure that I can get more detailed pictures and/or I can put you into direct contact with Chris.
Tim
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
M BN1 - Question about cold air box Austin Healey 6
AH100M 100m/100 Le Mans Cold Air Box grommets Austin Healey 5
A cold air box? Austin Healey 25
AH100M 100m Cold Air Box Grommets Austin Healey 2
C Cold Air Box for a 6 cylnder ? Austin Healey 13
RAC68 Cold Air Bilge Blower update Austin Healey 13
TRMark TR4/4A Cold air intake system Triumph 1
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
Morris Cold Air Intake Spridgets 2
D cold air duct 100 Austin Healey 3
J Replacing the cold air intake hose Austin Healey 22
E TR6 TR6 Cold Air Induction - Mixture Triumph 2
PAUL161 CAR COLD? How About Recirculating Hot Air! MG 8
L K&N Cold Air Intake MG 7
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 Pegged out hot while cold Triumph 7
B Cold Start Problems BN7 Austin Healey 21
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
N Running Cold Austin Healey 12
M Cold start problems Austin Healey 33
D it's cold and i'm bored... waiting for parts... Austin Healey 11
M Starting from cold Austin Healey 2
F TR2/3/3A Starts Cold, Not Hot Triumph 12
R Very Difficult cold weather starting problems! Austin Healey 21
K Hard Start, runs poorly when cold Spridgets 10
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
S Hard starting on Webers from cold Austin Healey 12
Lutz Kramer Problem starting the cold engine Austin Healey 16
drooartz MGB Must be the cold -- MGB will have a nice Xmas MG 7
M running cold Triumph 8
J Cold Starting on a Series II Jaguar 5
S Cold galvanizing zinc spray Restoration & Tools 5
N Cold Plug site shutdown! Other British Cars 19
tahoe healey How cold would you drive? Austin Healey 16
V hard start when cold Austin Healey 7
aeronca65t TR2/3/3A TR3-cold tires Triumph 2
H Cold blooded animal Triumph 21
nevets OD sluggish when cold Austin Healey 15
S Cold Start issue MG 4
tweety Cold Start thoughts Spridgets 6
drooartz A great [cold] drive today Spridgets 5
PAUL161 Just Brought "B" Out Of Cold Storage! MG 14
Morris Cold Start reality check Spridgets 10
theleisure Cold Weather, Oil Pressure Spridgets 10
T 100M Cold Airbox Filter Austin Healey 29
Thor Suggestions for hard starting 1500 when cold Spridgets 5
