TR2/3/3A Rebuilding A type OD I Need advise / measurements
JFeher
I've been collecting all the bits to complete the rebuild of my A type overdrive. I've completed installing the annulus and bearings in the rear housing and have good end float. I have the annulus thrustwasher and planet gears in place. I have the Moss# 866-560 thrust washer between the planet gear housing and sunwheel. After placing the thrust washer and spacer on the sunwheel I put the main housing on and installed the main shaft. The sun wheel end float should be .014-.020. I have .2. I think have every washer and bushing called for installed. I have read that to install the thrust washer in the planet gear housing requires the removal of one of the planet gears. I was able to slide the 866-560 thrust washer into place with out doing that. It's just a flat brass bushing with a taper on the side that faces the sun wheel. I can't figure out why I have such a gap. It does seem like the sun wheel is too low in the planet gear housing in how it fits within the planet gears. Does anyone have measurements of these items or have an idea of what I may be missing? It's a 22 61985 unit.
Thanks,
John
CJD
I have not measured, but the thrust washer inside the planet set is in the neighborhood of .2" thick. I see no way you could slide the old out or new in without removing a planet gear. Do you have a picture?
JFeher
JFeher
The bushing I got from Moss #76 in the Moss diagram part# 866-560 (to the left of the sun wheel) is only.0093 I think that may be the problem. Look how deepthe sun wheel sits in the planet gear housing.
attachment.php
attachment.php
TR3driver
Great Pumpkin - R.I.P
Is there any chance you have mis-matched parts? ISTR reading that the 28% gear set will allow that washer to be replaced without removing a planet gear (because the lower gears are smaller).
On my 22% set, there is no way it could be done.
Also, on my A-type that was severely over-pressurised, the case is apparently stretched. I had to add more than one adjustment washer to get the correct gap.
Worth noting, perhaps, that the spec for sun wheel end float was later reduced to .008" - .014". I suspect it may be advantageous to set the earlier units to that range as well.
JFeher
JFeher
The OD was a basket case (exploded) with a lot of missing pieces. I replaced the planet gears and housing and they match up with the old one. I have never seen a complete assembly so I'm going by all the references I can find, Buckeye Triumph, the manual and parts catalogs. Th planet gears that fit inside the annulus are smaller than the gears driven by the sun wheel.
CJD
That is normal for the 2 sizes of gears. Your sun is definitely sitting too low, but I cannot remember the shims that control that, other than the one captured inside the planet case. You can see in my one picture the 2 washer bushings that go on top of the sun gear. Those are the ones that control the amount of sun gear float. But still, your sun is sitting too low. The gears must have full contact across their faces.
I assume you are using the original sun with the replacement planet set? I wonder if they could be mis-matched?
TR4nut
A remote possibility to check - I believe Wishbone Classics machines the planetary gear housing to accept a thicker thrust washer. If by chance your housing has been machined the stock thrust washer would sit low which would make the sungear sit low too. That also might explain how you can get a thrust washer in there, in stock configuration I agree with Randall, I don't think the washer can be fit because of interference with the planetary gears.
TR4nut
The 28 % version will definitely allow the thrust washer to be replaced with no interference issue as Randall mentioned. I put one in my last rebuild - the washer is different from what you have as it doesn't have the outside bevel, but I don't recall it being thicker so I'm not sure what is causing your excessive clearance issue.
TR3driver
JIC it's not obvious, the 28% gears don't need the bevel, as the bevel is to provide clearance to the larger 22% gears. The difference in gear sizes is what gives the OD gear ratio.
When you shift into direct drive under power, the splines bind to some extent, and the motion of the clutch disc slams the sun gear into that thrust washer. With a tight clearance, the sun gear doesn't move very much and the impact is minimal. A larger clearance allows more of an impact. Hence, I believe, the reduced clearance specification, to reduce breakage of that thrust washer. But a thicker washer would certainly help too (as would reducing or eliminating the oil grooves). I intend to try that if mine breaks again.
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
jollyroger rebuilding 64 E- type brakes Jaguar 2
B Tips on rebuilding E-Type power brake master/slave Jaguar 4
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
bighealeysource Rebuilding BN2 generator Austin Healey 5
