Rebuilding BN2 generator
bighealeysource
Bronze
Believe my BN2 generator might need the bush or bearing replaced. This looks like a relatively simple job but probably be the repair from heck ! Anyone do this lately ? Or as another alternative, a good source to have it rebuilt ? It's charging fine but get some bearing noise with a new belt so all of this might be more preventative type maintenance.
Thanks,
Mike
Johnny
Not hard to do if you have the manual. No special tools required. I did have a bearing puller that came in handy, but lacking that you can "split" it and pull it out with a chisel and longnose pliers. While apart check the points and clean the armature as well.
5
57_BN4
Hi Mike,
Very easy job to change the bearing and probably worth doing the rear bush and brushes as well. The parts are fairly common although some people seem to sell 'kits' on Ebay for very high prices
The bearing is held in by three rivets which can be gently pushed out in the vise with a socket and thin punch. I have reused mine ok with the assistance of a ball-peen hammer upon reassembly.
To get the rear bush out of the end plate, first put a small piece of plastic or wood down the hole to protect the oil-retaining felt then wind a coarse tap into the bush which will bottom out on your bit of plastic and pull the bush out. To lubricate the new bush, sit it on your thumb so one end is sealed, then fill it up with engine oil and squash the other thumb into the top. Keep doing that a few times until oil runs out all around the outside surface, then dump the oil out. Skipping this step will result in rapid wear as the bush is porous and traps oil in the tiny holes.
Also worth looking at the insulation on the stator windings, if it is oil soaked or falling apart then you can redo it using some cotton tape from a sewing store and spray it liberally with clear paint once completed.
Andy.
EV2239
eBay is expensive for Lucas Dynamo bits, I paid £27 for a new exchange one at my local motor factors. That's $40 and on eBay you pay £69 or $100.
I used to rebuild mine, but the problem is that the field winding insulation breaks down, which means that unless the wrapping is removed, the coil opened out and stripped of shellac and then re-dipped and bound again, it may not last long.
Therefore I recommend finding someone who does all this and there must be more in the Sttes than here. Also it's worth giving him the regulator at the same time so that the two are set for each other. They last for years if they are in good order.
bighealeysource
bighealeysource
Bronze
Hey y'all,
Thanks for the advice and descriptions. This will make a nice winter project! Did check about if I had it on too tight as switched to a cogged belt which does not need to be on as tight as a non cogged belt. Not too tight but as sure as I go to reduce some of the slack, get the whine. Cannot use the factory manual guidelines for tightness with the cogged belt. Norman Nock even recommended a cogged belt in his Tech Talk so I'll stick with this new one.
Thanks,
Mike
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
E TR6 Rebuilding Distributor Triumph 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
Xte Rev counter rebuilding ... Austin Healey 2
J TR6 rebuilding tr6 rear hubs Triumph 13
H head rebuilding mods Austin Healey 15
