TR6 Rebuilding Distributor
EddyTx225
Hi all,
Relatively new mechanic here. I recently inherited my late father's 76 TR6 and want to get it back on the road. In the process of getting it started I have rebuilt the carbs, and now want to start on the distributor. I believe that a rebuild is in order so I ordered a rebuild kit from Moss. I have also ordered a pertronix electrical ignition (LU 166A). I don't know electrical stuff much at all so I feel a bit intimidated and I've struggled to find easy simple step type advice on how to proceed. I also believe the lucas coil is probably done for as well so I think that I need to order a new one. My questions for you experts are thus:
How can I figure out which exact coil to buy? Looking online and there are so many different ones that have all sorts of different specs. I bought a voltmeter but don't know how to really use it to check.
Are there any good guides out there for rebuilding distributors when I have all the replacement parts? I followed some easy guides for the carbs and would love something similar for the dizzy.
Thanks!
Sarastro
Do you have a shop manual? Brooklands republishes most (if not all) of them. The TR4/4A one is a little spotty, but still essential. In any case, it will have all the specs you need.
Don't be intimidated by electricity. This is your chance to learn about it, as long as you are open to finding out stuff. You really don't need to know more than I did when I was 10 years old; the rest is just logic.
poolboy
Just what is included in the distributor rebuild kit from Moss ?
If you don't know the names, can you post a picture ?
As far as the coil...the 76 was sent from the factory with a 1.5 ohm coil..but some owners bypassed the resistor and went with a 3.0 ohm coil....
The Pertronix Ignitor LU166A works best with the resistor bypassed
I think you are going to need this.
Read Chapter 31
S TR2/3/3A Rebuilding a cylinder head Triumph 30
S TR2/3/3A when rebuilding a differential Triumph 9
M TR2/3/3A Rebuilding suspension Triumph 29
G Rebuilding Front Seats Austin Healey 4
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
S TR2/3/3A Engine Rebuilding. Triumph 14
L MGB Rebuilding a 1977 MGB MG 1
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
KVH General Tech Rebuilding the Engine Triumph 5
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
drooartz Rebuilding rear axle Spridgets 19
T Rebuilding a 1275 for a BE Spridgets 8
pkmh Rebuilding Armstrong Lever Shocks on a BJ8 Austin Healey 28
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
steveg Rebuilding roadster windshield Austin Healey 24
A Rebuilding Tiger window regulator question Sunbeam (Rootes) 3
S TR2/3/3A Rebuilding Dr2 Lucas wiper motor Triumph 16
S TR2/3/3A rebuilding bomb nose starter Triumph 9
W Looking for engine rebuilding 100-6 Austin Healey 12
KVH General Tech Rebuilding the Engine--a few practice pointers [for me] Triumph 11
R TR2/3/3A Rebuilding H4 carbs Triumph 8
S TR2/3/3A rebuilding door panels Triumph 15
Rut TR4/4A Seat rebuilding Triumph 3
steveg Rebuilding the Dip Switch Austin Healey 9
Tinkerman TR2/3/3A Rebuilding SU carbs 1960 TR3A Triumph 3
Rut TR4/4A Seat rebuilding Triumph 6
CZ_Dave MGB Is it worth doing the Shock Conversion Kit or Rebuilding Exsisting shocks? MG 16
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
KVH TR4/4A Engine rebuilding Triumph 17
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
pbraun Anyone have a 1275 core for rebuilding? Spridgets 8
Got_All_4 TR2/3/3A Continually Rebuilding of my J Type Gear Box Triumph 2
drooartz MGB-GT Rebuilding the seats MG 28
Gray_Cat MGB Rebuilding MGB Overdrive MG 4
S TR2/3/3A rebuilding a tr3 water pump Triumph 22
Lin Rebuilding a master cylinder for BT7 Austin Healey 3
PatGalvin TR2/3/3A Guide for SU Rebuilding Triumph 8
H TR4/4A 4A convertible top rebuilding sequence Triumph 8
sim Rebuilding Front Suspension 58 sprite spring question Spridgets 6
Lukens TR2/3/3A More questions about rebuilding my steering box Triumph 20
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
S TR2/3/3A Transmission Rebuilding Triumph 29
L 1966 BJ8 frame rebuilding questions Austin Healey 1
djackson Rebuilding 100/6 Transmission Austin Healey 6
bighealeysource Rebuilding BN2 generator Austin Healey 5
Xte Rev counter rebuilding ... Austin Healey 2
J TR6 rebuilding tr6 rear hubs Triumph 13
H head rebuilding mods Austin Healey 15
