TR2/3/3A shifting tower shifting rods on an early tr3 tower
sp53
Will the shifting tower shifting rods on an early tr3 tower that is drilled out for the OD switches work properly for an OD or are the shifting rods different.
TR3driver
Great Pumpkin - R.I.P
Yes, the rods are the same for either OD or non-OD. They changed for synchro 1st, though.
S
sp53
Randall thanks again. I have like 4 old trannys lying around and was gutting out the shifters to find or make up the best out of the bunch that would have a factory dip stick hole. I drill one out a while back, but looking at the others they are in better shape. I just need to put the switches in one of the older towers, but was concerned I was missing something; it looked too easy. Your knowledge has helped me out many times and I appreciate it. You are probably one of few that would know that and you willing to share.
When I move the switches, are there any critical measures to follow. I see the shims and just do not know how critical the fit is. I am just getting acquainted with the Over Drive. I am driving the car, but have the fenders off the car still, so I have not driven fast enough to engage the OD. I am doing the carpet and with the fenders off, so I am less likely to bang into the car crawling in and out.
steve
TR3driver
The cover castings will even interchange between 3 synchro and 4 synchro if you change the shift rods.
The book talks about the shims being important, in the section on adding OD to 2nd gear. I forget the exact procedure offhand, but its the usual measure the gap and subtract some magic number.
One of the articles on the Buckeye website talks about having to mill off the top of the cover to get the recommended setting. Might be something to watch for, if you're adding your own holes. I'm sure you could just file it down, if you don't happen to have a mill handy.
ISTR he also mentioned the hole location being fairly critical.
CJD
The only thing...I know the TR2 2/3 shift rod does not have the OD bump on it for the OD switch...so it is different. The rest should all work.
Install the switches with the cover off the box, and then you can monitor how the shift rod and switch ball are interacting.
TR3driver
The OD bump is not on the shift rod, its on the fork. All TR3-TR6 have them.
All but the last couple thousand TR2 did lack the bumps for OD in 2nd & 3rd, but the later forks will still fit and work with the early top cover (a factory supported retrofit).
S
sp53
Ok---you guys-- do I have to move the forks over to the earlier shift tower along with the switches or are all the later forks the same? Is there and OD fork?
S
sp53
Ok after I read Randal’s post better after the shock. I can that all means all. Plus they look identical. See, I like both you guys, and yes it takes a good man to admit when he has missed something. At least that is what I tell myself when I confuse something and Randall brings it to my attention. He was wrong once I remember.
TR3driver
So all clear?
Anything you want to know, It should be perfectly clear.
You see just beneath the surface of the mud,
There's more mud here...
-- David Crosby, "Anything at all"
CJD
So, I guess the summary is:
You can use any rod from any year, so long as they are from a non-1st synchro box.
You can use any fork from a non-synch box except the TR2 1/2 fork.
Since nothing is ever marked in TR land, it’s still clear as mud!
TR3driver
You also probably wouldn't want the 3-4 fork from an earlier TR2, as it won't have the ramp for OD in 3rd.
The ramps are easy enough to see, though, should be reasonably obvious if you look for them.
(Those are the 4-synchro forks, only photo I had handy.)
S TR2/3/3A drilling out shifting tower for a dip stick Triumph 10
S TR2/3/3A Tr3 shifting tower oil leak Triumph 3
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
AUSMHLY BJ8 Gear Shifting Austin Healey 5
L TR2/3/3A Shifting problems Triumph 4
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
M Grinding when shifting into first Spridgets 10
1 MGB 1966 MGB hard shifting into 3rd MG 1
Jim_Gruber Clunk in the rear when shifting Spridgets 26
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
C Shifting problem? Triumph 15
F Missing pieces- centershift 3000- vague shifting Austin Healey 4
J Difficult Shifting Triumph 8
britndablood Side shift tranny with shifting issues Austin Healey 10
longbridgehealey gears grinding when shifting Spridgets 11
J TR4/4A Hard Shifting TR4 Triumph 2
B Down shifting problems, check my thinking? MG 1
P Shifting a J2 MG 9
stretchit2 Side Shifting Tri Carp Austin Healey 14
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
R difficulty shifting/downshifting-BJ-7 Austin Healey 7
jaegzie Close Tranny shifting pattern Spridgets 0
R 1500 gearbox, trouble shifting into first from neu Spridgets 20
thechileman TR4/4A TR4 Shifting problem Triumph 3
R trouble shifting, getting into gear &stuck in gear Spridgets 22
I TR6 tr6 shifting problems Triumph 12
eschneider T-Series Clutch - shifting problems - help? MG 19
Bruce_B Shifting Triumph 3
Jayrz Poor Shifting 2nd gear MG 5
K TR6 73 tr6 tranny shifting Triumph 1
M Shifting Issue: Clutch Question Spridgets 4
R electrical shock when shifting to overdrive Spridgets 20
zimmy my gearbox shifting and rebuild video Spridgets 4
P shifting gears Triumph 6
tahoe healey tough shifting Austin Healey 16
I TR6 TR6 not shifting into gear Triumph 3
sultanoswing T-Series Shifting Dipswitch from floor to column MG 3
J shifting Austin Healey 16
B Car revs upon shifting gears MG 5
7 OD shifting hard! Triumph 6
T Shifting in/out of overdrive MG 4
Steve P. strange smoothcase shifting problem solved.... Spridgets 1
Whytock Shifting Troubles MG 2
M Shifting Trouble Spridgets 17
F Hard Shifting Triumph 14
