TR6 73 tr6 tranny shifting
KAllen
Member
Just getting back on the road with my TR after rear pinion seal RR - shifting from 1 to 2 is sometimes difficult and from 2 to 3 grinds a bit - new clutch - throw out, Pressure plate, disc, with correctly mounted slave - so engagement is not an issue and I had the flywheel resurfaced and replaced center bearing. Down shifting same difficulty to 2 from 3 with need to double clutch to get it to drop in - I am guessing the syncros are worn on 3rd - but the upshift to 2 is confusing. Oil in tranny is TRF 80-90 wt gl3. would like comments on others experiences. Thinking that a rebuild is necessary or a swap to a 5 speed box.
As many others have learned, replacing components is no guarantee that you don't have clutch drag. The acid test is (with the car stopped but engine running) to depress the clutch then hold it down while you first shift into a forward gear, then into neutral, wait a few seconds, and try to shift into reverse. If it grinds even a little bit, your clutch or pilot bearing is dragging.
My experience has been that 2nd gear wears out first, so it wouldn't be surprising if both synchro rings are tired.
Got_All_4 General TR This Happened Twice [TR6 tranny in a TR3] Triumph 17
GTP1960 TR2/3/3A tr6 Type A OD tranny service Triumph 10
Got_All_4 General TR Tranny Fork alinement problems & TR3 shifter in a TR6 tranny Triumph 17
charleyf TR2/3/3A tr6 OD tranny on a TR3 engine Triumph 7
T TR6 TR6 Tranny Triumph 10
Brian_Lekas TR6 TR6 Tranny removal Triumph 19
2wrench TR6 Cost to rebuild TR6 overdrive tranny. Triumph 12
L TR6 TR6 tranny Triumph 6
ICE MAN TR6 TR6 Tranny on a TR3B Triumph 3
G building a TR6 OD tranny for vintage Racing 4
J TR6 1975 triumph tr6 engine and tranny - bid idea's Triumph 0
bigbadbluetr6 TR6 tr6 tranny conversion? Triumph 11
tr6web TR6 TR6 Manifold gasket help Triumph 0
mctriumph TR2/3/3A R&D completed on Tr6 fan conversion Triumph 2
Hawk813 TR6 TR6 Brakes Triumph 5
M For Sale 1971 Triumph Tr6 Triumph Classifieds 0
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
Charlypm For Sale 69 Triumph TR6 Racecar Triumph Classifieds 1
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 5
R TR6 TR6 Triumph 6
