TR2/3/3A Shifting problems
Lodi Ron
I just replaced the clutch master cylinder and slave cylinder on my 1961 Triumph tr3a. Everything was working fine before the replacements. Now it still shifts fine until it doesn’t and it doesn’t a lot. It locks up in neutral and until you shut it off, move the shifter around until it will go into gear again. Has anyone had a problem like this and how was it resolved?
CJD
It sounds like air in the system. The fact it works sometimes implies the adjustments are correct, so air is the likely cause.
sp53
+1 with John, sometimes you can use gravity to bleed. Put a tube on the zerk and put the tube into a jar and open the zerk. I have done it that way. It takes a long time for the fluid to drip out just keep an eye on it. I would say you have hours. I would probably close it after an hour.
steve
L
Lodi Ron
steve
Thanks Steve
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
B Down shifting problems, check my thinking? MG 1
I TR6 tr6 shifting problems Triumph 12
eschneider T-Series Clutch - shifting problems - help? MG 19
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
AUSMHLY BJ8 Gear Shifting Austin Healey 5
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
M Grinding when shifting into first Spridgets 10
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
S TR2/3/3A drilling out shifting tower for a dip stick Triumph 10
1 MGB 1966 MGB hard shifting into 3rd MG 1
Jim_Gruber Clunk in the rear when shifting Spridgets 26
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
C Shifting problem? Triumph 15
F Missing pieces- centershift 3000- vague shifting Austin Healey 4
J Difficult Shifting Triumph 8
britndablood Side shift tranny with shifting issues Austin Healey 10
longbridgehealey gears grinding when shifting Spridgets 11
J TR4/4A Hard Shifting TR4 Triumph 2
P Shifting a J2 MG 9
stretchit2 Side Shifting Tri Carp Austin Healey 14
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
R difficulty shifting/downshifting-BJ-7 Austin Healey 7
jaegzie Close Tranny shifting pattern Spridgets 0
R 1500 gearbox, trouble shifting into first from neu Spridgets 20
thechileman TR4/4A TR4 Shifting problem Triumph 3
R trouble shifting, getting into gear &stuck in gear Spridgets 22
Bruce_B Shifting Triumph 3
Jayrz Poor Shifting 2nd gear MG 5
K TR6 73 tr6 tranny shifting Triumph 1
M Shifting Issue: Clutch Question Spridgets 4
R electrical shock when shifting to overdrive Spridgets 20
zimmy my gearbox shifting and rebuild video Spridgets 4
P shifting gears Triumph 6
tahoe healey tough shifting Austin Healey 16
I TR6 TR6 not shifting into gear Triumph 3
sultanoswing T-Series Shifting Dipswitch from floor to column MG 3
S TR2/3/3A Tr3 shifting tower oil leak Triumph 3
J shifting Austin Healey 16
B Car revs upon shifting gears MG 5
7 OD shifting hard! Triumph 6
T Shifting in/out of overdrive MG 4
Steve P. strange smoothcase shifting problem solved.... Spridgets 1
Whytock Shifting Troubles MG 2
M Shifting Trouble Spridgets 17
F Hard Shifting Triumph 14
