bigjones
Say you are going down the road and are about to turn onto a side road that goes uphill. You would naturally shift from 4th to 2nd, right?
Well, I can't seem to do this - there is much gnashing of gears. Is this normal for the TR3/4 gearbox?
I've just adjusted the slave cylinder to give 10 thou end float - is that right? I mean this is a TR3A but has a TR4 gearbox (all synchromesh, ar, ar!) Incidentally, why would the clearances be different - the TR3A spec is 87 thou. Anyway that didn't make any difference.
There is no other issues at all with the clutch/gearbox.
Many thanks for any suggestions!
