TR6 TR6 Trans in a TR3...What about clutch?
karls59tr
Bronze
If a TR3 motor is Supercharged to 150HP will the stock clutch hold up? What is the HP and Torque of a TR3 and of a TR6.
TR3driver
Great Pumpkin - R.I.P
IMO you're not likely to have any trouble with either clutch. The early PI TR6 used the same clutch as the carb'ed version, and was rated for 150 bhp. The TR3 clutch is actually larger and IMO stronger than the TR6 clutch.
K Anyone racing A TR3 with TR6 trans? Racing 0
EWD TR6 ā€˜74 TR6 Starter & Trans Cover Triumph 13
K TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved. Triumph 6
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
S TR6 If I put a rover V8 in TR6 what trans can I use? Triumph 2
A TR6 Motor install--with or without trans.??, [TR6] Triumph 12
tr6web TR6 Trans leak - TR6 Triumph 4
Y TR6 TR6 5 speed Trans Triumph 10
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engineā€¦ Triumph 7
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ā€˜74 TR6 original wheel trim rings Triumph Classifieds 3
