TR2/3/3A TR3A with TR6 trans Clutch Bleed Issue Resolved.
karls59tr
Bronze
The issue was the pedal only engaging about half way to the floor and sometimes not at all.After unsuccessfully trying to bleed the clutch hydraulic system using every conceivable method including reverse bleeding and pressure bleeding I removed the slave cylinder exterior "return spring"and got firm pedal immediately. What's the technical explanation for the spring's negative influence on the slave? I understand the TR6 did away with the outside return spring. The odd thing is I drove for 10 years with the TR6 trans that had that return spring in place???
TR3driver
Great Pumpkin - R.I.P
The TR2-4 throwout bearing was not designed to run all the time; the return spring is what pulls it back from the pressure plate so it doesn't. The TR6 bearing is a special free-running design that should run with only very light pressure (from the spring inside the slave cylinder) to load it into the pressure plate fingers.
Sounds like you aren't getting the pushrod adjusted properly; plus your return spring is too weak to reliably return the piston home in the slave. You may recall I warned you about that before.
K
karls59tr
Bronze
When I removed the slave return spring the clutch then operated perfectly and the pedal is where it is supposed to be.I can now shift with no issues. Is my throw out bearing running all the time now? I thought you mentioned once that were running your 3 with the return spring off as well?
TR3driver
Meybe. If not, you may start hearing a squeal as it rubs against the pressure plate fingers.
But I may be worrying about nothing. Geo Hahn reports that his TR3A works fine without the return spring.
No, just without the extra tab to increase the return spring tension (and compensate for the shorter pushrod). But I also have a TR6 style TOB, to go with TR4A clutch & aluminum flywheel. And I had planned to install the tab last weekend, I just didn't get it done. The variation in clutch engagement is starting to bug me.
K
karls59tr
Bronze
Is there a chance you had the spring pulling in the wrong direction?
The spring was hooked up in the normal location. The clutch works well without the spring....not sure why ....I'm just happy it's now drivable.:joyous:
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
T TR6 TR6 fan on TR3A Triumph 21
D TR6 Looking for TR6 caliper "brackets" for TR3A conver Triumph 12
B TR6 TR6 "A" Overdrive fitted to a TR3A? Triumph 12
J TR6 TR6 fan in TR3A question Triumph 9
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
