master cylinder brake/clutch Tr3
mctriumph
Be aware there is a batch of brand new, AM replacement masters, that are defective when you get them.
The symptom is extreme difficulty in bleeding the system and then having to do it again and again.
The manufacturer has (on mine at least) omitted the tiny waffle washer on the tip of the end valve. If
you have been cursing and thinking you no longer know how to bleed a system of air, IT aint YO Fault.
MD
Grantura_MKI
Be there done that one with a Jaguar unit.
The waffle washer as you call it is very important to the operation.
TEXAS_TR3A
Member
MD
Thanks for this post. Just replaced my clutch master and slave about a month ago, only to have mediocre results with soft clutch and grinding gears periodically unless I pump the clutch a few times before shifting. Bled it twice more and same result. Perhaps this is the reason.....
mctriumph
mctriumph
Yes it most certainly is. the real laugher was the reply from the retailer saying as how it all my fault
that after 50 years of wrenching I am doing it all wrong. The cheesy buggers wont admit how wrong they are till
they face a courtroom full of angry jurors. Some where some body will get hurt I am afraid.
MD
Expatriot
MD
Hi MD having the devil of a time bleeding the clutch system On my 59.
Installed both new master and slave as well as flex hose to the slave and a new reservoir.
slave is installed properly and has the correct adjustment on the rod.
have bled using two person method, reverse bleeding, and pressure bleeding.
no leaks anywhere except a tiny mount behind the slave dust cover.
so replaced the slave, again. bench pressure bled it before installing.
no leaks behind the rubber.
pedal is great for about a day, just sitting In the garage
out for a drive and had no clutch after about three miles
pump like crazy and get enough clutch to make it home.
no leaks behind the dust covers on either the master or the slave.
or anywhere in the fittings.
so having replaced the slace twice, is the consensus i may have a bad master cylinder from the guys
whose name is the same as the green stuff that grows on the north side of trees?
Been bleeding hydraulics for at least 50 yrs and cannot fathom this one.
inclined to get a new master from bpnw.
Any comments, or am i up a tree on this one?
thanks expat.
Expatriot
MD
Hi MD, so what did you do to fix your problem?
Obtain another master from someone else?
Rebuild the one you had adding the missing waffle washer? If so who has that?
Rimmer has an mc but its a repro, oems are on back order till for ever.
Anywhere else for an alternative source?
cos right now I’m thinking WTF? after 50 yrs of working on old brit iron.
donbmw
Just installed a new master cylinder for the brakes on mine from them. Had no issues.
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
D BJ8 brake master cylinder question Austin Healey 6
D TR2/3/3A Brake Master Cylinder. Triumph 4
Michael Oritt Brake Master Cylinder access Austin Healey 0
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
M TR6 Brake master cylinder question. Triumph 2
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
T TR2/3/3A another brake master cylinder question Triumph 16
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
D MGA Master Brake Cylinder Leak MG 2
nevets question about brake master cylinder Austin Healey 12
Lukens More clutch / brake master cylinder questions. Triumph 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
KVH Bleeding the Brake Master Cylinder Triumph 8
J TR6 TR-6 Brake Master Cylinder Seepage Triumph 4
J TR6 TR-6 Brake Master Cylinder-Rebuild or Replace ? Triumph 4
D Brake master cylinder Austin Healey 1
A Divided brake master cylinder MG 6
1 Brake Master Cylinder Spridgets 11
K TR4/4A TR4A Brake Master Cylinder Internal Spring and Triumph 13
letemglow Brake line layout with dual master cylinder MG 6
Gliderman8 Brake Master Cylinder info Triumph 1
doughairfield Brake Master Cylinder leaking Triumph 11
J TR4/4A TR4 Master Brake Cylinder Rebuild Triumph 3
letemglow Adjustable rod on brake master cylinder Austin Healey 3
S BRAKE LINE MASTER CYLINDER Triumph 1
doughairfield Master Brake Cylinder Rebuild ? Triumph 18
T MGA What color should an MGA brake master cylinder be? MG 6
letemglow Brake master cylinder BJ8 Austin Healey 0
dklawson Spitfire Brake Master Cylinder Quality - Spitfire MkIV Triumph 2
Camshaft Brake Master Cylinder Rebuild Spridgets 11
D Wedge Power Brake Booster/Master Cylinder for TR7 Triumph 4
E Is this Brake Master Cylinder Salvageable? Triumph 23
Q TR2/3/3A TR3 Brake Master cylinder rebuild Triumph 5
VelodromeRacer Brake master cylinder upgrade? Racing 4
B Brake Master Cylinder R&R MG 12
