What is the correct tool for removing brake lines from a BE Master Cylinder
Jim_Gruber
ok just discovered I do not own whatever tool is needed to remove BE Brake Lines from a BE Master Cylinder. Tried bending up a cheap 7/16" flare Nut Wrench but still can't get the right angle. What's the secret guys perhaps a Crow Foot Box End Wrench?
Jim_Gruber
Jim_Gruber
Flare Nut End is what I meant . Complete Set $11.99 at HF. Time to buy a Metric Set as well as new Brake lines Have Metric Nuts on them. Time for a little more PB Blaster and then a trip to HF this PM.
I have a cheap offset line wrench with a flex head. I bought it at autozone. It seems to work well.
Jim_Gruber
Jim_Gruber
Thanks Trevor. I'll check that out. Never got to HF last night.
I looked at the wrench last night it say "great neck" on it.
Jim_Gruber
Jim_Gruber
K thanks
nomad
I've always been lucky enough to be able to remove them with just a stout open end wrench. I'm going to be looking for Trevor's wrench now though.
Kurt.
Jim_Gruber
Jim_Gruber
Found it at AutoZone. Works really slick. Duralast Brand now. $14.95 it saved the day and actually made the job easy. 7/16" and 3/8 " open ended FlexHead Brake Line Wrench.
Pedal Box and MC is out for paint and cleanup. Pedals are a little bit ovaled out where they attach to the MC but not enough to get the welder out to close up the holes and redrill.
Wire Wheel treatment, need to degrease, and then paint. And yes I did separate the Brake Pushrod from the Clutch Pushrod and marked as they appear to be of a different length. At least they are adjusted that way.
INFLATION... when i bought it in 2008 I'm sure it wasn't over $8.
nomad
I'll bet that the company is now a huge holding company and its made in China as well!
Kurt.
Jim_Gruber
Jim_Gruber
More than likely. But it worked.
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
