TR2/3/3A Throttle shaft assemble does this look correct
Got_All_4
Should have taken a pic of the assembly before disassembly. Anyway is his correct?
TR3driver
Great Pumpkin - R.I.P
I think the flat washer should be on the other side of the brace. There should be a snap ring that the washer rides against, with the brace against the washer and then the spring on the other side of the brace up against the lever.
And IIRC, you have to have the engine out to install the pedal and shaft as a unit. Otherwise the pinned joint has to come apart.
Got_All_4
Got_All_4
Engine is out. Don't remember any snap ring. Still can't find my manual and probably wouldn't be pictured anyway.
TR3driver
Sorry, my mistake. It's a cotter pin, not a snap ring.
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
J TR2/3/3A Need a part for the throttle shaft. Triumph 4
B Pics of throttle shaft reaming Austin Healey 6
C TR6 Broken Throttle Shaft Triumph 4
E TR4/4A TR4 Throttle shaft position Triumph 1
glemon General TR Those Darn Throttle Shaft Bushings [TR4-6] Triumph 8
A SU throttle shaft and bush dilemma - advice? Triumph 41
glemon Rebuilding stromberg Carbs Throttle Shaft Bushings Triumph 6
M Throttle shaft problem!! Austin Healey 5
M_Pied_Lourd TR2/3/3A TR3A Throttle Shaft Bushings Triumph 15
J Test for wobbly throttle shaft? Triumph 9
luke44 TR2/3/3A TR3 - Re-assembly of Throttle Shaft Triumph 8
R SU Throttle shaft Bushings MG 22
T ZS throttle shaft - how to determine excess wear Triumph 15
eschneider anyone have a throttle shaft reamer for sale? Restoration & Tools 6
F TR2/3/3A TR3 Carb Throttle shaft Triumph 10
tomshobby throttle shaft bushings Triumph 15
Harry_Ward TR2/3/3A TR3A throttle shaft bearings Triumph 23
Brosky TR6 Replacement throttle shaft bushings for TR6 Triumph 24
John Loftus throttle shaft bushings Austin Healey 12
Lin Freeing throttle shaft levers Austin Healey 11
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 34
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
