TR2/3/3A Throttle linkage cross rod
Frank Canale
I have removed the throttle (accelerator pedal) linkage from the fire wall. The rod that crosses between the bearing mounts is slightly bent, very obvious and does not look factory. Should this rod have the bow to it or should it be straight? Frank
TR3driver
Great Pumpkin - R.I.P
Should be straight. But its easy to bend when removing or installing the engine.
Geo Hahn
Yeah, mine was bent - still worked okay. As Randall notes... probably occurred during and engine pull of a gearbox removal (engine raised too much).
F
Frank Canale
Thanks for the information. The hard part was getting the pins that hold the linkage to the rod. Once they were out I was able to tig up a groove worn in the shaft by the spring washer. The cross rod was easier than I thought it would be to straighten. All the linkage has been bead blasted and put away in a tote to be painted at a later date. I have not decided on what paint to use on bits and pieces and brackets. Still a ways down the road. Frank
sp53
I have never seen a straight one, but I have straitened a few out. I am not sure, but they might all be black and there a 2 types. On the early one the gas pedal on the end comes off. I bought some of the nylon bushings before and they were too big, so a good stock set up maybe as good as it gets. Take some pictures of stuff like that on a tr3 because that pedal goes in kinda counterintuitive. Plus get the pedal back in before the motor. It will go back in with the engine in place, but only after lots of prayer.
steve
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 34
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
C TR6 Carburetor Throttle Linkage Triumph 10
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
MY66AH Throttle Linkage Spridgets 9
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
newmexTR3 TR2/3/3A TR3 Throttle linkage pics needed Triumph 19
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
A TR4/4A TR4A Throttle - Lower linkage length Triumph 1
vette Throttle Linkage Ball Joints Austin Healey 5
T Keeping the throttle linkage shiny Triumph 5
DrEntropy Alfa throttle linkage? Other Cars 3
MrBlueSky Wedge tr8 edelbrock throttle linkage Triumph 2
R GT6 Need to see GT6 Mk1 Throttle linkage Triumph 9
drooartz Throttle linkage question Spridgets 6
Zimmycobra Throttle linkage saga continues Triumph 5
Zimmycobra TR4/4A TR4A throttle linkage Triumph 6
Got_All_4 TR5/TR250 TR250 throttle linkage problem Triumph 6
T TR2/3/3A TR3 Throttle linkage return spring Triumph 3
D Ratco Throttle Linkage Triumph 8
J Healey 3000 - throttle linkage [cable] Austin Healey 11
T TR6 Picture/diagram of TR6 throttle linkage Triumph 7
bighly Improved throttle linkage MG 1
philman Wedge TR8 Throttle Cable linkage help Triumph 3
G Throttle switch and linkage Austin Healey 5
T Throttle linkage question Triumph 2
chicken Throttle linkage for BJ7 Austin Healey 6
B BJ7 Throttle Linkage Problem - Access? Austin Healey 6
D Ratco Throttle Linkage Triumph 31
vping Throttle linkage - I need a pic MG 13
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
S HS2 SU dual carb throttle/choke linkage Spridgets 10
tosoutherncars DGV throttle linkage help needed Spridgets 4
X Throttle linkage sticking Spridgets 6
DrEntropy YO! Brosky!!! [RE: Throttle linkage couplings] Triumph 15
Brosky Throttle linkage from Ratco Triumph 35
P Throttle linkage on 1967 LHD. BJ8 Austin Healey 5
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
G Triple Stromberg throttle linkage Triumph 12
S Adjusting Throttle Linkage Austin Healey 3
mbrooks BN2 throttle linkage Austin Healey 1
Lin Carb Linkage and Throttle Cable Austin Healey 3
