Throttle Linkage
MY66AH
I'm having an issue with my throttle linkage. It feels like it's binding. I replaced the throttle cable thinking that was my issue but wasnt. Is there a way the carbs should be tightened down? Any ideas would be appreciated. Thanks in advance. -Chris
SaxMan
Did you check the throttle return springs? There should be three of them, IIRC. Sometimes they wear out or snap. I had only two on my '69 at one point and one of them snapped while driving. The remaining spring was not sufficient to get the throttle to come back, so the car started running away from me. Fortunately, I realized I had a stuck throttle and was able to kick the clutch and kill the motor before I hit anything.
The other thing you can do is disconnect the springs from the linkage and see if the linkage itself is binding anywhere. It could be something in the linkage is bent or might just need lubrication.
nomad
You can remove the cable at the throttle bell crank end pretty easily. Make up a little funnel of heavy card stock and tape around the cable sheath and pour a little oil in while you hold it vertically. Cable lubed!
Kurt.
Maybe the clamps that hold the pedal itself are binding from rust or other debris?
SaxMan
+1 - When I pulled my gas pedal, the hinge was very, very stiff. I was actually quite amazed that the pedal was able to snap back as stiff as the hinges were.
Rut
I've forgotten the specs, but there should be a small gap between the throttle linkage stop and the heat shield. When installing the carbs make sure that neither of the linkages binds where it fits into the 'socket' of each carb. I've never had to lubricate any of the carb parts when properly aligned and they should all move smoothly.
Rut
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 34
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
newmexTR3 TR2/3/3A TR3 Throttle linkage pics needed Triumph 19
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
A TR4/4A TR4A Throttle - Lower linkage length Triumph 1
vette Throttle Linkage Ball Joints Austin Healey 5
T Keeping the throttle linkage shiny Triumph 5
DrEntropy Alfa throttle linkage? Other Cars 3
MrBlueSky Wedge tr8 edelbrock throttle linkage Triumph 2
R GT6 Need to see GT6 Mk1 Throttle linkage Triumph 9
drooartz Throttle linkage question Spridgets 6
Zimmycobra Throttle linkage saga continues Triumph 5
Zimmycobra TR4/4A TR4A throttle linkage Triumph 6
Got_All_4 TR5/TR250 TR250 throttle linkage problem Triumph 6
T TR2/3/3A TR3 Throttle linkage return spring Triumph 3
D Ratco Throttle Linkage Triumph 8
J Healey 3000 - throttle linkage [cable] Austin Healey 11
T TR6 Picture/diagram of TR6 throttle linkage Triumph 7
bighly Improved throttle linkage MG 1
philman Wedge TR8 Throttle Cable linkage help Triumph 3
G Throttle switch and linkage Austin Healey 5
T Throttle linkage question Triumph 2
chicken Throttle linkage for BJ7 Austin Healey 6
B BJ7 Throttle Linkage Problem - Access? Austin Healey 6
D Ratco Throttle Linkage Triumph 31
vping Throttle linkage - I need a pic MG 13
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
S HS2 SU dual carb throttle/choke linkage Spridgets 10
tosoutherncars DGV throttle linkage help needed Spridgets 4
X Throttle linkage sticking Spridgets 6
DrEntropy YO! Brosky!!! [RE: Throttle linkage couplings] Triumph 15
Brosky Throttle linkage from Ratco Triumph 35
P Throttle linkage on 1967 LHD. BJ8 Austin Healey 5
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
G Triple Stromberg throttle linkage Triumph 12
S Adjusting Throttle Linkage Austin Healey 3
mbrooks BN2 throttle linkage Austin Healey 1
Lin Carb Linkage and Throttle Cable Austin Healey 3
