twas_brillig
Our DCOE equipped Yellow BE is locked away for the winter and not accessible, but my recollection is that there is a lug on the goose-neck intake manifold that secures the outer casing of the stock Sprite throttle cable and allows the inner wire to connect to the Weber DCOE. We're assembling the Silver BE and the intake does not have such a lug; it does have a flat place on the rear runner that is tapped for two small diameter bolts plus a pair of larger tapped holes on the inlet flange of the manifold, but my pile of miscellaneous does not have anything suitable to mount there.
Any suggestions regards building or sourcing a suitable linkage system would be appreciated.
Thanks
Doug
Thanks
Doug
