Looking for advice on XJ6 overdrive unit speedo drive
krswen
I am going through the transmission on my Panther which uses a 1974 XJ6 S2 Type A Laycock overdrive. I removed the brass "bushing" (part 10866 in the parts book) and took off the external o-ring that seals it to the tailshaft housing. Looking inside I saw what looked like another o-ring about halfway down the bore which seals the shaft of the drive gear itself. I went in with a hooked o-ring tool and lo and behold it's a lip seal! A tiny lip seal complete with garter spring. They must have installed it with some arcane magic because it is placed inside a bored o-ring gland and I cannot fathom how they did it.
Long story short, I butchered it trying to remove it while I still thought it was a simple o-ring. It does not show up in any parts book images. I'm actually going to have to go in with a small boring tool on my lathe to get the remainder of the pieces out. I'm hoping the dimensions will be that of a standard o-ring gland and I plan to use one to replace it.
Any experience in this area? Or am I screwed and need to buy a new assembly, which presumably has the lip seal already installed ($112 From SNG).
Ken
Keoke
XK's Unlimited may have it too
The Jag forum is just below us too, so you can check there also.
krswen
krswen
Discovered that it comes apart in two pieces once you drill out a tiny pin. Now have the replacement seal (under $5) and ready to reassemble.
Ken
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
S TR6 new TR6 owner looking for advice Triumph 9
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
A Newbie Bugeye Sprite Mk1 owner looking for some advice Spridgets 49
W TR2/3/3A Engine rebuild - looking for preliminary advice Triumph 7
HealeyRick Looking at a Bugeye - Any Advice? Spridgets 12
pbraun Looking at Bugeye - any advice? Austin Healey 32
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
T looking for racing suspension advice Austin Healey 1
britlover TR5/TR250 Looking at TR250, has issues, need advice Triumph 9
C looking for advice on selling my Midget Spridgets 21
S MGB-GT New MGB GT owner, looking for some general advice. MG 18
B Looking for a TVR - Some advice needed TVR 12
B Looking at a MKI Midget today - need advice Spridgets 10
M Advice for looking at a 79 Midget 1500 Spridgets 43
TR4nut Looking for long term car storage advice Triumph 10
T MGB Looking at a 74 1/2 MGB need advice MG 30
Brosky TR6 Looking for tire advice for TR6 Triumph 17
J GT6 Looking for a GT6 and some advice. Triumph 17
Steve P. TR4/4A Looking at TR4 tomorrow...advice needed ASAP Triumph 7
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
