TR6 Carburetor Throttle Linkage
CSFairfield
I am putting the engine back together and am at the point of installing the Carbs and linkage and can’t find a definitive view of how to put all the bits back together.
Additionally I can’t seem to source the washer with the 2 tabs that lock the front nut in place. The rear one I found at TRF but can’t get the front. I may have to use the old one? Seems like a critical part.
poolboy
The rear carb doesn't use that 'lock tab' washer. It's an internal tooth lockwasher.
The locking tab washer is used on the front carb's throttle shaft's 'extension nut'.
I'm not exactly sure what you're calling linkage though.
Would that be the mechanism that transfers motion from the accelerator shaft to the throttle shafts or the linkage that connects the throttle shafts to one another ?
If the former, better post the year because there are 2 versions.
C
CSFairfield
Linkage being the bits that connect the front carb to the rear... I orders a locking tab and it fits the rear carb spindle not the front.
I’ve laid out the bits in the order I think they go.
top to bottom is rear to front
poolboy
If you look in the TRF 'blue' catalog at Plates AU thru BB you'll see that the locking tab washer is "ONLY" for the front carb's extension nut and the rear carb "ONLY" has a "shakeproof" washer which is an internal tooth lock washer.. The word "ONLY" comes directly from the part description in the catalog....making me wonder what's going on with your parts.
Anyway...here's a picture of the throttle shaft couplings
C
CSFairfield
Triple checked the trf part number and it is correct but is too small for the front throttle shaft but fits the rear piece that connects the linkage to the shafts. TRF lumps it in with something called ‘sounds couple assembly. That’s where the tabbed washer I got fits. Weird.
poolboy
Something is 'weird'..either on TRF's end or on your end.
This is how it's supposed to be:
Rear carb:ZS carb throttle shaft ends 003.jpg
Front carb:ZS carb throttle shaft ends 002.jpg
poolboy
You will have to imagine there are carbs on the throttle shafts...The throttle shaft for the rear carb is much longer than the throttle shaft for the front carb...there is no extended nut on the rear carbs' throttle shafts
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
FlyingCat Spitfire No Gas to Carburetor Triumph 18
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
ckeithjordan TR2/3/3A Carburetor Rebuild Triumph 26
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
SMGoose Carburetor piston not falling freely Triumph 7
D Carburetor Backfire on acceleration at low speed Austin Healey 18
