S.U. HD8 Carburetor Drawing
dmorris1
Member
Hi Everyone,
I thought I would share my drawing of Austin Healey S. U. HD8 Carburetors that made for the Art and Craft show at Enclave 2015. I also made prints of the drawing, which is limit to an edition of 50. If interested you can contact me. I drew inspiration for Ausmhly and his beautiful car. My BJ8 just went under a three year restoration a year and a half ago, still working out the bugs a year later and probably a life time.
attachment.php
attachment.php
David
dmorris1
Member
I forgot to mention the bottom image is the print of the drawing. I use prismacolor pencils( a brand of color pencils) to do the drawing of the carburetors and 3000 emblem.
AUSMHLY
Hi Everyone,
attachment.php
attachment.php
David
Wow, great drawing!
I went to RISD and some of my pictures were of chrome items and drawing white objects on white backgrounds.
Is this the photo you drew from?
I see a couple things different. Center ball end, yours faces left, mine right.
2 screws that hold the clamps around the center fuel line, yours slots mine philips.
Some other items different. Really really nice drawing!
PS. I should have said... OMG, I did a drawing of a set of HD8's as a homework assignment when attending RISD. Here it is!
Dmorris1, your drawing looks better then the reall thing!
So, when you're at your next car show and someone says, wow your carbs look great, you can comment...thanks, but take a look at these, they look even better. Show the drawing.
Your engine compartment looks like mine, same valve cover painted green too, chrome acorns, etc.
attachment.php
dmorris1
Member
Thanks, Great complement coming from you. I been drawing all my life. I'm currently an art professor teaching drawing and printmaking. Usually don't do car related artwork, but got totally obsessed with the Healey. Had one one I was a teenager, along story. I work with in a shop that let me work alongside of them. Part time job for three years, did about everything on the car. I like you took everything apart more then once sanded ,buffed and polished the carburetors. They where so beautiful, that I did a color pencil drawing of them working for the real carbs and photo. Over two weeks spent of the drawing, eight hours a day. The car is driver, which I try to drive everyday. Just drove it to the Enclave at Gettsyburg, Pennsylvania total miles 1300. Having a show of my drawings in New York in December.
Best,
David
AUSMHLY
Our engine compartment look alike too. Well except you can see that my engine is bigger, lol
attachment.php
attachment.php
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
pkmh HD8 SU Carburetor removal Austin Healey 48
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
Lin HD8 carbs Austin Healey 2
