HD8 Carbs
BOBBYR
Hi Guys,
I hope everything is good with all.The other day ,I had to pull apart the carburators on my 65.The reason I did this is cause I couldn't get the idle down below 900 rpm's.Anyway,I found that the adjusting jets were frozen solid in their bushings.Event though they are brass, they were so gummed up,they wouldn't move.I cleaned the parts with carb cleaner and ordered rebuild kits,but I'd like to make them look better before assembly.Can anyone recommend a way of making the aluminum look alittle brighter and a way of polishing the top vacuum chambers? As always,thanks Gang,
Bobby R
Dave Russell
Yoda - R.I.P
Good old fashioned carb cleaner, the type in a gallon can with dip basket works quite well. No plastic, rubber, non-metal parts in the cleaner.
If you try any machine polishing of the chambers be very careful to not drop or dent them. The slighest distortion will cause the piston to bind. Also do not interchange the chambers & pistons. They are factory fitted as an assembly & frequently won't interchange without binding problems.
BOBBYR
BOBBYR
Hi Dave,
Thanks for the advice.It's been so long since I've worked on carbs ,that I wasn't sure if they still sell the old 5 gallon cans of cleaner.I've been real careful not to mix up the parts of theses carbs and the moss parts came in today ,so I think I'm pretty well set.I can't wait to see how they adjust now.Thanks for your help,
Bobby R
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
wangdango Colortune for HD8 Carbs? Austin Healey 55
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D Rebuilding the SU HD8 carbs Austin Healey 24
S Float Level for HD8, BJ8 carbs Austin Healey 9
D K&N filters for HD8 carbs Austin Healey 26
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
A BJ8 SU HD8 carbs for sale Austin Healey 0
Lin HD8 carbs Austin Healey 2
M New Member with an HD8 Carb Question Austin Healey 1
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
B mysterious leaking of SU HD8 Jaguar 9
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
