Question about SU HD8 carb gasket kits
David_K
I bought a set of gasket kits from Moss and I have already noticed that the float chamber gaskets need to be stretched over the rim to fit. Is this normal or is there a better quality kit out there for these carburetors?
Thanks /ubbthreads/images/graemlins/hammer.gif
David_K
David_K
Nevermind,
I friend has recommended Joe Curto, but he suggested soaking the gaskets to make them work instead of sending them back.
Ed Kaler
[ QUOTE ]
[/ QUOTE ]
I agree, David UNLESS there is a HUGE difference. /ubbthreads/images/graemlins/confused.gif
Might I make a request for all the OFs that have their monitors set to 800 x 600 for EASE of viewing?? Please reduce you INCORRECTLY labeled /ubbthreads/images/graemlins/hammer.gif sig pic to about 500 wide?? /ubbthreads/images/graemlins/angel.gif
Ed
David_K
David_K
Not a huge diffence but I'll try again when I'm done polishing the carburetors.
Btw, You should step up to a monitor that views at 1280x768. Best thing since sliced bread. /ubbthreads/images/graemlins/smile.gif
Ed Kaler
[ QUOTE ]
[/ QUOTE ]
This VERY nice 21" flat is capable of even better. It's just EASIER of these (and LOTS of others) to look at said 21" at 800 and be able to NOT strain eyes!! Mine are 6 decades old.
Whats that prob with shrinking the pic?? Don't know HOW??
This OF can do it for you and send to you if you want.
Geesh
Ed
David_K
David_K
The text size in your browser can be enlarged seperately. At 1280x768 I still have 3" to the right of my signature.
M New Member with an HD8 Carb Question Austin Healey 1
J SU HD8 Question Jaguar 11
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
