TR6 question re: Engine Oil
Gliderman8
Always 20w-50
I've used various brands as long as it has ZDDP... such as Valvoline VR1, Kendall GT1 or Penn Grade 1
+1 on the Penn Grade 20-50. I just bought a case last week.
JPSmit engine oil cooler question Spridgets 11
jjbunn TR6 Engine Oil Level Question - TR6 Triumph 12
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
L TR2/3/3A Stupid Engine cleaning question Triumph 9
H MGB Engine build question MG 10
M 948 Engine Rebuild Question Spridgets 0
L TR2/3/3A Engine plate question Triumph 5
JPSmit Kind of an engine question Spridgets 11
T Sunbeam/Hillman engine question Sunbeam (Rootes) 6
KVH TR4/4A Engine Question: The Valve Lifters Triumph 9
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
M MGB Help with engine code question. MG 5
JPSmit Question two - leaning out the engine Spridgets 6
NutmegCT Flat head [L-head] engine question Other Cars 5
S General TR Engine Serial Number Question - Observation on a TR4A Triumph 3
T TR4/4A Question on engine block Triumph 8
2billydavies TR2/3/3A question about where to bolt into when lifting/replacing engine Triumph 11
2billydavies TR2/3/3A question about 1958 TR3a engine number, body number, etc Triumph 7
TulsaFred Engine Install motor mount question Spridgets 5
F TR6 Starter Relay = Low Engine Power Question Triumph 13
A 100 engine main bearing cap nut question Austin Healey 0
JPSmit Engine Rebuild question Restoration & Tools 10
2billydavies TR2/3/3A dumb question of the day: engine fan for TR3a position Triumph 11
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
R low/high temp engine running question Spridgets 23
7 General Tech Engine vacuum, tuning question Triumph 7
T TR2/3/3A having no shame I ask another question about a TR3 engine that is giving me fits Triumph 10
J 1800 engine question MG 14
S engine is back, tub is bare,frame is bare Question Triumph 9
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
B TVR with Essex V-6 engine question TVR 5
B Curious question..Engine Coolant container MG 10
JPSmit Engine Question Restoration & Tools 5
H engine paint question Austin Healey 19
B Wedge Tr8 engine removal question. Triumph 13
JPSmit Viva GT question [seized engine] Other British Cars 5
NutmegCT TR2/3/3A TR3 engine question Triumph 6
S Spitfire Question on VIN and engine number for spitfire Triumph 5
S old question maybe?, rebuilt engine Triumph 3
BN6_2197 Question on Engine Compression Austin Healey 9
A question about media blasting and engine paint. Austin Healey 14
J Engine Question Austin Healey 7
MGTF1250Dave TR4/4A TR 2-4A Engine Dissassembly Question Triumph 5
14dna Nissan Engine Question Spridgets 5
H Engine rebuild question Triumph 6
J Engine Swap question Spridgets 25
UmmYeahOk Chassis/Engine # Question Triumph 12
T Engine pulling question - where connect Triumph 10
P General engine question Triumph 5
