TR4/4A Sellers Reconcilliation Question
JDstr4a
Haven't posted in ages but still working on my preservation project off and on. I removed the passenger door panel and found this attached. I'm assuming the POE is Port of entry but have no idea what the EOH charge is. Any insight would be greatly appreciated.
Thanks
JD
J
JDstr4a
According to Heritage Certificate it's a 65, titled as a 67. I haven't even attempted to get that corrected.
NutmegCT
JD - I'd think the Certificate showing 1965 manufacture, would take priority to an owner or potential buyer, over a DMV car registration data record. USA data records for non-USA cards are often just guesses by the DMV clerk at the computer.
Andrew Mace
When I bought a 1967 Sports (Herald) 1200 convertible some 10 years ago, it somehow had been registered in New York as a 1964 model. How that could have happened, I don't know, but NY's DMV accepted the data on the BMIHT certificate as proof that a May 1967-built car was, indeed, a 1967 model!
That said, I suggest leaving the paperwork as-is. If nothing else, it likely tells the history of a car that just plain didn't sell for the better part of two years, or perhaps one that a dealer held onto for other reasons (demonstrator? personal use?), after which time the car was finally sold and first titled as a 1967. Back then, one could easily get away with that. Even manufacturers like Triumph could do that legally. By 1968, when Federal safety and emissions standards came into play, model year / year of manufacture dominated.
J
JDstr4a
Agreed, not high on my list. It was nice to find the paperwork, as the po had little. The cert said it was delivered to Midwest distributors in Chicago. I read somewhere they had a roll in the demise of the brand in the US. I'd rather chase history from that perspective when its too cold to tinker.
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
R TR6 Starter wiring question Triumph 6
K TR2/3/3A TR-3B carb question Triumph 13
S TR2/3/3A Steering question Triumph 37
