MGB Quick question about something that don't really matter just want to know.
T
titanfan10
Bronze
Just a quick question, recently started looking at MGBs to possibly buy one. This is not a big deal just wondering why some 1980 MGBs have a 120 mph speedometer and some only have 80 mph speedometer? Thanks for any answers.
drooartz
Assuming these are USA market cars, I'm guessing its because of the law passed in 1979 that mandated speedometers could only read to 85mph here. That could easily explain the mix of speedos as it was phased in -- even as the MGB was phased out.
Did a little quick Googling and came across this on Hemmings: "Unique to 1980 models were the regulation-required 85-MPH speedometer and six-digit odometer."
As to why some are 120, could have been replaced, could have been phased in, could have been changed mid-run depending.
YakkoWarner
Learn something new every day - I didn't know that there were 85MPH speedos in any MGB's.
With all the detuning in the later years I'd almost have guessed that the answer to this question had something to do with loss of performance,
I guess the remaining question would be; was any factory MGB actually capable of going 120 and who would have been crazy enough to find out.
drooartz
All cars sold in the USA in the early 80's had those 85mph speedos. Particularly strange on your brand new Porsche or Ferrari. Trying to get us to drive slower to save gas. Didn't work, and by 1981 the law was repealed. Took a few more years for manufacturers to switch back. An oddity of the times.
I love my B and I do drive it reasonably ard, but even getting close to 120 would be sketchy. 🤪
Joe Reed
The 85mph speedo was a US market only "feature" for the 1980 model year. I suppose some owners probably swapped them for the earlier units over the years since the original looked kinda silly in a sports car. One thing to look at is the odometer. I'm pretty sure all 1980 cars had a 6 digit odometer for 1980 regardless of destination. That includes those (such as Canadian market cars) that displayed KPH instead of MPH.
It's also quite possible that some 1979 models actually get registered as 1980 cars in some locales. If so, they would still have the earlier 5 digit odometer.
billspohn
A 1980 is the last vintage you'd likely want - worst handling and weakest performance of any MGB. Shoot for an early 1970s car instead. And I'd hold out for one with overdrive.
I had fun once with my old Lamborghini - it was a home market car sold in Rome in 1969 so had a metric speedo that went up to 300 kph. I was standing near that car once and a kid called out to his friends - "Hey, this one will do 300 miles an hour! I didn't have the heart to tell him what it really meant.
The speedo always goes a bit higher than the cars will really go. The 120 MGB was about 10 mph higher than they could attain and my MGC speedo that showed 140 mph was 20 mph higher than a stock one would do (though my modified one did c. 130 mph several times)
YakkoWarner
Even if the MGB can "only" get to 110, thats way faster than I want to go in anything that doesn't have wings. A section of toll road around here has a posted 85MPH speed limit - even that is more than I'm comfortable with. If I get my B assembled I'm hoping it will be able to cruise without straining at between 65 and 70, thats about all I want to go.
billspohn
That is sensible, but if you care about good handling, the earlier cars are significantly superior, aside from the fact that the single carb engines are relative slugs.
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
S MGB 1980 MGB quick question MG 2
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR6 Quick TR6 alternator question Triumph 6
M Quick tachometer wiring question on a '65 Spridgets 10
Willie_P Quick question: rear diff TR 3/4 Triumph 6
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
MCNX_BFF Quick catch-up and trailer question Triumph 8
skelly Quick question from a newbie Spridgets 10
PatGalvin Captive nuts?? quick question Triumph 7
JPSmit Quick Spark plug question Spridgets 10
Sarastro Quick dumb transmission question Spridgets 9
T Quick fuel pump question - mounting angle MG 3
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
bigjones HS4 - quick question MG 6
JPSmit Quick HS4 Question MG 2
T don't have my book, quick torque question Triumph 5
JPSmit Quick Transmission question Spridgets 2
L A quick question for you UK/European LBCers Spridgets 0
Jim_Gruber Quick Carb Question Spridgets 16
bigjones Quick alternator question Spridgets 16
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
D Quick Question C to F Restoration & Tools 4
JPSmit Quick Carb Question Spridgets 2
theleisure quick clutch question Spridgets 10
T Quick 1275 question on a Mini motor Spridgets 2
tosoutherncars HEEELP! Quick soft top question Spridgets 7
T TR4/4A Quick question on TR4 battery Triumph 7
JPSmit Quick question #2 Emergency Brake Spridgets 1
Stewart Quick wiring question MG 6
cmacmillan TR6 Quick question on Haynes for TR6... Triumph 3
J TR4/4A Quick TR4A wiring question Triumph 6
jlaird Quick question Spridgets 5
jjbunn Quick Speedo Question Triumph 14
JPSmit Quick Question - rear hub torque Spridgets 4
mlarnoldTR6 Quick question Triumph 2
RickB MGB Quick tire size question - MGB MG 10
JPSmit Very Quick Question - rear oil seal Spridgets 2
P Quick Coil Question. Triumph 3
JPSmit Quick rear brake question Spridgets 56
T A quick silly Crypty question. Triumph 3
Webb Quick Alternator Wiring Question Triumph 3
Trevor Jessie Quick question...really [about line fitting] Spridgets 14
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
tosoutherncars QUICK QUESTION - manifold bolts Spridgets 3
Sarastro Just a quick, dumb generator asssembly question Spridgets 2
JPSmit Quick Spring Question Spridgets 10
