Quick question - 1500 wiring for coil
tosoutherncars
Hi all,
I foolishly pulled off all five connectors when replacing my coil. Now I have five wires, and I'm not sure which are supposed to connect to which posts.
They're all the original wires, white with various stripes (blue, green, etc.) Anyone have a wiring diagram handy? And/or, I have a multimeter; how can I check which ones go where?
TIA,
Duncan
Morris
The white/green wires (should be two going into one connector) go to the positive terminal. The blue/white wire(s) connect the tach. The remaining wires will depend on which replacement ignition system you have as it is EXTREMELY unlikely you have the stock OPUS(croakus) ignition system that came on the car.
On my car, the DPO had taken the many connectors left over from the OPUS system and just kinda plugged them in "where ever."
tosoutherncars
tosoutherncars
Done! For once, the Haynes seems to have been correct... White & green / White & black to the coil, White & Blue / Solid White to the resistor. Hasn't started yet, but that's more due to lack of throttle cable and/or lack of carb settings. Thanks guys!
I am a little puzzled as to one wire... the black, fabric-covered wire that used to attach to the outside of the distributor, and that is energized when the key is in the Acc/On positions.
What the heck do I do with this thing now, chop it off & wrap it up?
-D
G
Just wrap it up. With my setup all I had to do was find power when the ignition was energized.
You got your tach connection, right?
Morris
Ugh! Black/white to the negative terminal. I am sorry. The blue/white and the resistor is left over from the opus croakus. The black wire looks like a ground. If you disconnect the green/white from the positve side and turn the key on, do you still get power to the black wire?
T MGB Quick question about something that don't really matter just want to know. MG 9
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
S MGB 1980 MGB quick question MG 2
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR6 Quick TR6 alternator question Triumph 6
M Quick tachometer wiring question on a '65 Spridgets 10
Willie_P Quick question: rear diff TR 3/4 Triumph 6
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
MCNX_BFF Quick catch-up and trailer question Triumph 8
skelly Quick question from a newbie Spridgets 10
PatGalvin Captive nuts?? quick question Triumph 7
JPSmit Quick Spark plug question Spridgets 10
Sarastro Quick dumb transmission question Spridgets 9
T Quick fuel pump question - mounting angle MG 3
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
bigjones HS4 - quick question MG 6
JPSmit Quick HS4 Question MG 2
T don't have my book, quick torque question Triumph 5
JPSmit Quick Transmission question Spridgets 2
L A quick question for you UK/European LBCers Spridgets 0
Jim_Gruber Quick Carb Question Spridgets 16
bigjones Quick alternator question Spridgets 16
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
D Quick Question C to F Restoration & Tools 4
JPSmit Quick Carb Question Spridgets 2
theleisure quick clutch question Spridgets 10
T Quick 1275 question on a Mini motor Spridgets 2
tosoutherncars HEEELP! Quick soft top question Spridgets 7
T TR4/4A Quick question on TR4 battery Triumph 7
JPSmit Quick question #2 Emergency Brake Spridgets 1
Stewart Quick wiring question MG 6
cmacmillan TR6 Quick question on Haynes for TR6... Triumph 3
J TR4/4A Quick TR4A wiring question Triumph 6
jlaird Quick question Spridgets 5
jjbunn Quick Speedo Question Triumph 14
JPSmit Quick Question - rear hub torque Spridgets 4
mlarnoldTR6 Quick question Triumph 2
RickB MGB Quick tire size question - MGB MG 10
JPSmit Very Quick Question - rear oil seal Spridgets 2
P Quick Coil Question. Triumph 3
JPSmit Quick rear brake question Spridgets 56
T A quick silly Crypty question. Triumph 3
Webb Quick Alternator Wiring Question Triumph 3
Trevor Jessie Quick question...really [about line fitting] Spridgets 14
tosoutherncars QUICK QUESTION - manifold bolts Spridgets 3
Sarastro Just a quick, dumb generator asssembly question Spridgets 2
JPSmit Quick Spring Question Spridgets 10
