    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
A quick question for you UK/European LBCers
lesingepsycho
Hello,
I've been interested in putting fuel injection on my A-series 1973 MG Midget. I was looking at the Classic Mini MPI setup used from 1996-2000 in the UK and wondering:
1)if the manifold will bolt up on the MG Midget (i can't see any reason why it wouldn't??? A or A+ Engine should be compatible, right?)
2)if anyone has experience making this modification
I have a built megasquirt system that I believe could handle all the engine management. I have all the required parts for an EFI conversion seeing as I was expecting a Rick Patton TBI conversion but that hasn't been going to smoothly so I'm looking at some other options.
Thanks,
JACK
T MGB Quick question about something that don't really matter just want to know. MG 9
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
S MGB 1980 MGB quick question MG 2
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
S TR6 Quick TR6 alternator question Triumph 6
M Quick tachometer wiring question on a '65 Spridgets 10
Willie_P Quick question: rear diff TR 3/4 Triumph 6
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
MCNX_BFF Quick catch-up and trailer question Triumph 8
skelly Quick question from a newbie Spridgets 10
PatGalvin Captive nuts?? quick question Triumph 7
JPSmit Quick Spark plug question Spridgets 10
Sarastro Quick dumb transmission question Spridgets 9
T Quick fuel pump question - mounting angle MG 3
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
bigjones HS4 - quick question MG 6
JPSmit Quick HS4 Question MG 2
T don't have my book, quick torque question Triumph 5
JPSmit Quick Transmission question Spridgets 2
Jim_Gruber Quick Carb Question Spridgets 16
bigjones Quick alternator question Spridgets 16
livinginthepast Quick question on setting fast idle/balancing carb Spridgets 21
M TR2/3/3A Quick TR3 Question .Trans cover color Triumph 6
D Quick Question C to F Restoration & Tools 4
JPSmit Quick Carb Question Spridgets 2
theleisure quick clutch question Spridgets 10
T Quick 1275 question on a Mini motor Spridgets 2
tosoutherncars HEEELP! Quick soft top question Spridgets 7
T TR4/4A Quick question on TR4 battery Triumph 7
JPSmit Quick question #2 Emergency Brake Spridgets 1
Stewart Quick wiring question MG 6
cmacmillan TR6 Quick question on Haynes for TR6... Triumph 3
J TR4/4A Quick TR4A wiring question Triumph 6
jlaird Quick question Spridgets 5
jjbunn Quick Speedo Question Triumph 14
JPSmit Quick Question - rear hub torque Spridgets 4
mlarnoldTR6 Quick question Triumph 2
RickB MGB Quick tire size question - MGB MG 10
JPSmit Very Quick Question - rear oil seal Spridgets 2
P Quick Coil Question. Triumph 3
JPSmit Quick rear brake question Spridgets 56
T A quick silly Crypty question. Triumph 3
Webb Quick Alternator Wiring Question Triumph 3
Trevor Jessie Quick question...really [about line fitting] Spridgets 14
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
tosoutherncars QUICK QUESTION - manifold bolts Spridgets 3
Sarastro Just a quick, dumb generator asssembly question Spridgets 2
JPSmit Quick Spring Question Spridgets 10
